Results 1 to 9 of 9
Thread: Bad N75?
    Registered Member Two Rings tdubz's Avatar
    Aug 16 2007
    Bad N75?
    Im having a problem I had Revo stage I and would boost 16 pounds and then when I added the test pipe it would go to like 17-18, then recently the car started feeling slow so I got stage II and the boost only goes to 15 pounds and wont hit 21, and from time to time when im on the highway in 5th gear and play with the throttle it will go up to about 20 then drop down but still feels slow, do you think this could be a bad n75?
    2003 Audi A4 1.8T l Revo stg2 l Boosted Tech CAI l RS4 Sway Bar l Podi Boost Gauge l 20% Tints l VMR Test Pipe l Magnaflow 14851's
    Feb 17 2005
    Sarasota, FL
    Re: Bad N75?
    What are your SPS settings on?
    Feb 17 2005
    Sarasota, FL
    Re: Bad N75?
    And with the stock turbo typically boost levels are 20-21 spike immediately dropping off to 18 and tapering down to 13-15 by 6k
    Aug 16 2007
    Re: Bad N75?
    I dont have a sps, and when Im driving it will spike at 15 and then slowy drop down to 10psi a little before redline
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    Re: Bad N75?
    pressure test for a boost leak before labeling a bad N75.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: Bad N75?
    yup, sounds like a boot leak, i would check for that first.
    Aug 16 2007
    Re: Bad N75?
    yea I did a pressure test and there was a check valve that broke and replaced but still the car is doing the same thing
    Apr 25 2007
    MA
    Re: Bad N75?
    and you're sure that there isn't an additional leak somewhere?
    Aug 16 2007
    Re: Bad N75?
    there might be I have to check again
