Results 1 to 22 of 22
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Am I only one of few? (Front Camber Issues)
    I have only seen a handful of threads that reguard the front camber issues we face when lowering our cars. I have so far went through 2 sets of tires (I am going to swap the fronts around to get a little more life out of them, but that is such a pain to do that ever so often).
    the solutions I have found so far
    CPP adj control arms:
    It looks like they either went out of business or no longer selling?
    http://www.newdimensions.com/catalog...CPP%20Products
    I cant find it for our application -- plus the price is ridiculous its not even worth it rather buy tires ever 6 months. Plus I've read they make a great amount of noise and are really a race application
    kmac bushings
    essentially a press in bushing that gives some play to adjust the camber when the bushing is rotated
    Here ya go: Clicky click
    they seem like a cheaper alternative but I don't know how effective they are.
    auroa bushings
    similar to that of the kmacs I dont think it will give enough play to fully adjust the camber issues, but I am not fully educated on this concept either.
    http://www.hrpworld.com/index.cfm?fo...action=product
    finally I have read pure ms releasing something not sure if this is it
    http://www.purems.com/products/search.php
    but have yet to receive and reviews on it.
    whats your input on this? How do you guys deal with this issue?
    Buncha motorcycles
    Memphis, TN
    Re: Am I only one of few? (Front Camber Issues)
    CPP and STaSIS stopped selling their ACAs plus they were $700.... KMACs have to be pressed in and apparently are tricky to install..
    there is another manufacturer making a new set of ACAs that are supposed to be out around christmas i believe... no idea on price yet
    and yes i have the same problem.. on my third set of tires in 40k
    APR Stage 2/AWE Intake
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    CPP has been out of business for a while. Kmac is reputable, but I heard it's hard to fins shops that will press your bushings. Pure MS doesn't release that til the end of the year IIRC
    Oct 13 2007
    2004 audi a4 1.8t
    Owings Mills, Md
    When I lowered my vehicle and went to get it align. They told me that the camber was off and they would adjust it. I have put over 30000 miles on the car since and no tire wear issues. The alignment cost 350.00 though but was worth it.
    Feb 20 2007
    ct
    Quote Originally Posted by kdall82 View Post
    how low are you though?
    Quote Originally Posted by Papachristou View Post
    i don't feel so bad we are in the same boat then. I'm even considering buying really cheap 60/ea tires because of this.
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    on paper, my set up may seem weird, but when you see it, it looks fine.
    I ride 24.25" fender to ground in the front and almost 23" fender to ground in the back.
    Before, I was 22.5" all around and when I set it to that, I had about 50% of my tires left. They were down to the metal in about 5k miles.
    So far, I've put abotu that same distance on my new tires with my new set up, and they look brand new. The car looks good, it's still DUMPED, it handles very nicely, and i get great tire wear. You can go lower in the back since it does have camber adjustment, and no, my car doesn't look like a pre runner.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    If you search hard enough you can find CPP arms. I just bought a set from an AZ member.
    -Doug
    Feb 20 2007
    ct
    Quote Originally Posted by inaforest View Post
    SO was the alignment set at the higher or lower setting? if its at the higher setting makes a little more sense, my front is quite low i tuck a bit.
    you can even see the camber on that wheel.
    any feed back on them Doug?
    Deactivated Three Rings
    Apr 11 2008
    350?!? Holy balls! Thats insane.. my Audi dealer wanted 190 and I thought THAT was high! I went to a VW dealer instead and they did it for 95 + tax
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I have not installed them. Just got them Tuesday. They will be sitting in their box in my basement until next year when I put coil-overs on. One of those deals that you can't pass up.
    I was looking at them and its a simple design. I was thinking about finding a few sources to replicate them so we have adjustable control arms since there aren't really any available.
    -Doug
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    ^^^Yes, he really did.
    I've found that if you're at OEM Sport height down to 25" (considered track height), there's no uneven tire wear as long as you get the proper alignment. For me, 25" was the lowest I'm willing to go with all of the bad roads around here, so I'm glad the adjustable arms are going to be put to good use.
    USP CLUB MEMBER #34
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    Quote Originally Posted by vdubstreets View Post
    My alignment was done with the front at 24.225" and the rear at 23".
    I tuck in the back and not in the front, but it still looks good. I just realized I haven't posted one single picture since I joined this forum. I need to wash my car BADLY and then I'll take some over the weekend.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    ...and you got screwed out of $350 for a $100 alignment, congrats. The front camber IS NOT adjustable from the factory.
    And the rest of you can stop complaining about your camber.
    -Darrick
    Feb 20 2007
    ct
    Yea but you can set your car to a reasonable height do an alignment and drive around like that with a flip of a switch. Where I have to adjust coils
    I recall you doing some research that a a6 or a a8 had a adjustable control arm? I was going to look into that.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Hey Doug you might want to look into the applications for those. IIRC they were only made to be run with linear rate springs (because they usually have a smaller diameter).
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by actlsub9 View Post
    Thanks for the head's up. I'll look into it.
    -Doug
    Veteran Member Three Rings Carbon's Avatar
    May 24 2005
    2004 E46 M3
    San Diego, CA
    have you had an alignment since lowering the car? if not i would suggest getting one. if you are eating tires your problem most likely is toe not camber.
    03 A4 - Sold
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    go onto ebay and search for a entire front end kit,
    it includes the tie rods, control arms, etc. around $500 shipped. its OEM
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    I have camber issues and tire wear as well with my Eibach sportines... but only at the front. Tried doing an alignment twice and still the same, my front tires wear out bad on the inside but not the rear... Called Eibach and they said i would need a camber kit, beacause of non adjustable camber at the front...
    I'm about to say screw it and just get coilovers.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Senior Member Three Rings dirtyserby's Avatar
    Jan 28 2007
    Bay Area, Norcal
    Make sure you do an alignment each time you raise/lower.
    When you align your car, set the toe to 0.
    These tips helped me double the life of my tires.
    Im at 24.5 in off the ground with over -1.5 camber (dont remember the exact number)
    , -2 in the back.
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    Purems is selling adjustable upper control arms now.
    http://www.purems.com/products/product.php/II=2681
    Nov 14 2006
    Gig Harbor, WA
    Oooooh! Those are purdy!
    -Darrick
