Results 1 to 10 of 10
    Veteran Member Three Rings Alkemix's Avatar
    Apr 23 2008
    2019 Lexus NX (wifes)
    Newer OEM Fuel Pump?
    Well, I was looking into GIAC's X-Chip and went to check the fuel pump model that my car had come equipped with. I found that I have part # 06F127025H. This was not listed on the GIAC information page so just did quick google search to see what up with the new part number. It's a newer pump than the "F" version, but does anyone know what kind of improvements this pump has over the older "B" and "F" pumps? How much of an improvement is the APR or AutoTech fuel pumps compared to this newer "H" version fuel pump, if at all?
    Gone:
    2008 2.0T Quattro 6 MT Dolphin Grey / APR 91 / APR Catback / APR Intake / Sway Bars
    2013 S4 S-Tronic Black / Magnaflow / USS / STOCK
    Jun 05 2007
    Phillips Ranch, CA
    Re: Newer OEM Fuel Pump?
    I don't know how to really answer your first question because I am not sure on what stock fuel pump I have, but I have and early 07 and have been running the GIAC-X software for over 20k on the stock pump with no problems. I recently upgraded to newly revised Autotech Fuel Pump and couldn't be any happier with it, I have been running it now for about 3k and have had no problems at all with it. GIAC has yet to deliver the software for the upgraded fuel pump, but with the X-file I feel that as soon as I installed the autotech fuel pump in my car it adapted to the new fuel pump and I feel I have a slight more power from mid-range rpm to redline. I hope that helps to answer your question.
    Jul 21 2004
    South Florida
    That "B" versus "F" pump thing ended up being BS. There is no sig difference in the function of the pump (there was a small change to the bleeder I believe). Since the "F" pump there have been 2 more revisions and functionally, again, there is little difference at all. The issue is damage to the cams and buckets that occurs and it occurs on B pump cars, f pump cars, g pump cars, h pump cars, etc. GIAC made an assumption back in the B pump days that the new F pump was the magic fix but it turned out wrong. No need to update your pump unless it is not working properly.
    cheers! mike
    2018 Audi S5
    Gone-
    Apr 23 2008
    what about the issue of surging on the "B" pump vs. the "F" pump? Stock "H" fuel pump should be sufficient still with GIAC-X?
    Gone:
    Jun 05 2007
    Phillips Ranch, CA
    Agian Im not too sure what version of the stock I had but I was good for 20k. I do have to say agian how happy I am with the autotech fuel pump and its only $350 I believe. You should definitly be fine.
    Nov 12 2007
    Grand Junction, CO
    AWE will also be releasing a fuel pump shortly. It will be around $400.
    Established Member Two Rings I495 Bandit's Avatar
    Jan 08 2008
    01 St3+VW Jetta/06 A4 S-Line
    NoVA
    Quote Originally Posted by Alkemix View Post
    "Surging" is turbo and wastegate related and has nothing to do with the fuel pump. Fuel cut and hesitation at higher rpms is fuel pump related and it can occur with any version of fuel pump.
    Jul 21 2004
    South Florida
    Quote Originally Posted by I495 Bandit View Post
    word ^
    2018 Audi S5
    Gone-
    Senior Member Two Rings UrKurt's Avatar
    Sep 01 2007
    1990 325is, 2008 A4 2.0t
    California
    Quote Originally Posted by AudiWxGuy View Post
    I've been hearing this from you for a while, do you know when they are they doing this? Is $400 going to be a completely built pump (not including the core charge, obviously), or just the parts like the autotech pump?
    Established Member Two Rings kuwaiti's Avatar
    Dec 13 2008
    Kuala Lumpur
    Latest revision is "K" (released July 2009) which supercedes the "F" revision.
    I found out after my "F" version (with has KMD parts DIY) got messed up and fuel leaked into the engine, diluting engine oil. Audi had to replace my entire pump coz they said there was no way they could repair it.
    So, I am presently running revo Stg2+ on this new revised stock pump. Keeping my fingers crossed, no fuel cut yet. Car feels smooth and about the same as previously.
    Can't confirm this but one of the Audi OEM suppliers here said that the "K" version hpfp is shared by the S3 2.0T as well. Anyone could verify this?
