Results 1 to 11 of 11
    Registered Member Two Rings
    Oct 30 2006
    former s4 owner
    farmington, MI
    A4 springs on s4??
    has anyone here put lowering springs from a b5 a4 on a b5 s4?? I am wondering because I have an a4 that came lowered when i bought it, and dont feel like buying new lowering springs for my s4....
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    Re: A4 springs on s4??
    dude, you bought the wrong car.
    -Luis
    Oct 30 2006
    former s4 owner
    farmington, MI
    what????? i have an a4 in storage at a relatives house and i drive an s4.....
    Nov 02 2005
    S4
    VA
    yes.. you bought a 12k car. which still a 40k car for maintenance and modding purposes. .. .. i would think the spring rate on the a4 springs is not the same as the spring rate for the s4
    -Luis
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    It would probably make the car lower (the s4) than it did on the A4.
    Josh
    Veteran Member Three Rings slmds4's Avatar
    Sep 22 2005
    2022 Audi SQ5
    Atlanta
    If its quattro you can. I swapped my coilovers from my a4 to the s4. hope that helps
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by slmds4 View Post
    What kind of coilovers and what are the rates? Most of the major coilover players have different kits between A4/S4.
    08 S4- Stock SOLD
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Quote Originally Posted by mholme View Post
    ding ding ding.
    The S4 is heavier up front due to larger engine and added accessories and have a stronger spring. More than likely you will have to get new springs. What brand are they though. Some designed the springs for the S4 and use them on the A4 though.
    Join the OhioVW facebook group for gtg, show, and cruise instant updates!
    1998 VW Jetta GLX VR6 | 2001.5 Audi S4 6MT | 1984 VW Jetta GLi | 2004 VW Golf .:R32 | 2001 Audi TT 225 Coupe quattro
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    2.8 A4 springs will fit an S4 just fine. 1.8t springs wouldn't look so good and they might brake do to heavier engine.
    Established Member Two Rings lanoueb5er's Avatar
    May 25 2008
    2000 a4 1.8t Q
    montreal (I mean, Canada)
    Quote Originally Posted by GetAwayFromMe View Post
    x2
    Jan 29 2007
    08 S4 00 S4
    MD
    I don't think anyone doubts that they will fit just fine...but there's a reason that suspension manufacturers design springs with different rates for specific cars.
    08 S4- Stock SOLD
