First issue is I'm leaking coolant, fairly rapidly. The tank will empty out in apprx 3-4 days after filling. I noticed the leak is dripping somewhere at the back of the engine, just past the belly pan. I can see a pinkish crusty residue around the driveline.
Second issue, I think may be a clutch problem. If I'm crusing along in 4th or 5th gear and decide to accelerate hard, sometimes the rpms will shoot up, boost will build, but the car does not move...as if the clutch is not engaged. I have to let off the gas, let the rpms settle back down, and accelerate gently. However in 1st or 2nd gear, not an issue.
I also have a leaking prop shaft seal. Could this be related to any of the above? What could I expect to pay to have an independant shop take care of all this?
Thanks.
