Results 1 to 4 of 4
    Veteran Member Four Rings NorcalPB's Avatar
    Jul 16 2008
    Supercharged M3...sold/ Titanium B7 A4
    San Francisco
    Stripped air box screw
    After cleaning out my air box and putting it back together I noticed that one of the screws went all of the way in and the one that is closest to the front of the car was stripped. After screwing it in I noticed that it holds the box shut but there is a very very small distance that I can still push it down. Will this cause any problems? I was thinking about the cone filter/ heat shield setup a while back but I could be forced to pick it up even sooner than I was hoping...
    Jun 02 2008
    new york
    Re: Stripped air box screw
    No, its a stock airbox, your car doesn't have enough power to go through a bolt and a stipped bolt and break itself or throw a CEL for that matter.
    Get a cone filter, heat shields dont do anything. pitssshooooooooo
    Jul 16 2008
    San Francisco
    does a heatshield really not do anything? I thought you could warp your filter without it.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    youll probably be fine. but once you move to a cone filter and heat shield youll be much happier anyway.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
