Results 1 to 8 of 8
    Established Member Two Rings vdub203's Avatar
    Jun 25 2007
    east haven ct
    lm rep spacer /ride height question
    wats the lowest ppl have been running there lm reps 18x8.5 with the 8mm spacer out front 10mm out back 215/40/18 tire? i wanna still be able to slightly tuck if its possible...
    ride height now
    lm reps ive had forever that i jus got refinished
    05 s4 daily driver
    04 m3 dinan s1 jb/ir raven motorsports cage tckline bbs ect
    00 brilliant black s4. magnaflow, kw coilovers, awe tuning, piggies, bbs ch. ect ect..sold
    01.5 nogaro s4. apr catback, kw coilovers, some wheels with a lip..sold
    tt225, tt180, 97 m3, 95 m3, 94 skyline GTR .....all gone
    Veteran Member Three Rings mrbogangles's Avatar
    Apr 06 2008
    ;p
    phoenix az, bay area
    Re: lm rep spacer /ride height question
    i use 12mm and barely clear the calibers
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    I ground down the front caliper's a bit and ran a 2mm spacer...I had 19's tho
    Registered Member Two Rings SilverStr33k's Avatar
    Sep 29 2008
    01 B5 S4/STG3+, 03 SVT Focus
    Gurnee, IL
    i dont have lm reps, but i run 18x8.5 enkei sc05's, 35mm offest, no spacer 245/40-18 dunlops, and i am 1/4 inch wheel gap in front, 1/2 inch gap rears, mind you i have widened front fenders for the rs4 bumper, and i had to shave my rear control arms to clear the monster tires, with a 215 you should be able to slam that thing, especially with a spacer.
    "One time I left my exhaust open and someone stole my valve springs and my piston rings..."
    Ace of Spades Time Attack club member#1
    I will swap your trim (all of it) for $100!! not a bad deal to save your frustration!
    Jun 25 2007
    east haven ct
    Quote Originally Posted by mrbogangles View Post
    this is only protained to the front rear is no issue, i had a 10mm spacer off the rear jus to mock it up and the rim deff has some poke, but i can deff also run the 8mm which i am. idk how guys get away with running 2 or 5 mm spacers on the "bb5" lm reps? mabey cause there brake pads are worn enough that thell clear.. im willing to gring the caliper a little bit to run the smallest spacer as possible but i need to know wats the min size spacer how much grinding ect ect. has anyone heard of a little grinding and saftly running a 5mm spacer? that would be ideal
    05 s4 daily driver
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    Quote Originally Posted by SilverStr33k View Post
    ummm, 245 is by no means a "monster" tire.
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
    Sep 29 2008
    Gurnee, IL
    idk, they look big in there to me, specially cause they wouldn't fit with out the shaving, i do realize they are not crazy big, but the go from fender lip to control arm in the back, so...
    Jan 16 2008
    '15 S5, slippahs
    Home
    Hey SilverStr33k, got any pics of your setup? I just got my friends old 18x8.5 MOMO's and they got 225/40/18 on them and don't fill the rim up, kinda stretched on there and I don't like the way it looks. I wanna get wider ones like yours possibly, but was worried that a 245 series tire wouldn't clear the control arms. What tire do you have and do you have a pic of the shaving that you did? Does it affect the structural integrity of the arm in any way?
    TIA
