The past week I've notice a issue... I'll be in 3rd gear at WOT around 3500-4000 RPM and it's like I loose 50% of my power and the car shutters for a few seconds.. and then all goes back to normal while the RPM climb past 4500. Now this originally happen a few times only in 3rd gear so I'm thinking this must have something to do with the tranny. A day later I'm in 2nd gear at WOT and it does the same thing but now I get the flashing CEL which we all know is not good... Here's the problem, I get the flashing CEL but there is no error code recorded. So I pull over turn off the car and put the car in the stock chip mode since I have the APR software. I turn the car on the CEL is not flashing nor on at all. I go in to WOT and clearly do not have the power I would have with the chip enabled but I don't have any power lost or shuttering like before.
After talking to a friend of my that's a mechanic he thinks this has something to do with fuel delivery. I can say it is not the fuel filter because I replace it 2 months ago. I always use Chevron 92 octane fuel. I also replaced the air intake filter and spark plugs this June. One month ago I put in a new RS4 clutch with a new OEM flywheel. You can go to me site to see the detail of I've done.
So my only thoughts is I got a clogged injector, maybe a vacuum leak, or possible bad turbo. I've also been reading on how some people have similar problems when one of their EGT sensors go bad.
Any of you got any thoughts on my situation?
