When the piece in my transmission broke I initially thought that the shifter linkage went out of adjustment somehow so I started messing with the adjustment on the top and bottom bolt (top to move the assembly on the rails), bottom (to adjust the shifter to the linkage).
Well needless to say I put the transmission back in and tightened the linkage bolts back up inside the car and I cant get 5th or Reverse. It feels like I am trying to shift in to a brick wall!
I loosened the bottom bolt (to the linkage) and moved the shifter around and made sure it was in neutral then centered the shifter and tightened down, still no 5th or Reverse.
I have an ebay shifter if it makes a difference but I dont see why it would.
I watched the JHM adjustment video and did what it said (loosen bottom bolt move shifter around then center and tighen) but it wont work!
I am ready to throw a brick through the window or something! I remember when I put the shifter in it was a nightmare (took me like 3 hours) to get it to go in to reverse then as well. I didnt know about the move it around and put it centered then tighten bottom bolt deal though, but shit that aint working now either!
