Results 1 to 12 of 12
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Oil around diverter - PICS inside - help!
    I posted a while back about oil residue around the boost reservoir and the hoses going into my diverter valve. Here are some pictures. I think I have a leak - my car doesn't seem like it's holding boost like it did the first day or two after going Stage 1.
    Can anyone help me diagnose based on these pictures? I haven't done the boost leak test yet - wanted to make sure I know how to plug the PCV first. Martini's writeup shows the PCV on the TIP, and mine isn't like that.
    ...OR...
    Is this amount of seepage normal? New gasket? I don't think this is causing the residue around the hoses.
    The area around the DV and boost reservoir is where the problem seems to be - the bottom front of the engine.
    Anyone know what hose the nasty one is? Without getting under the car I can't tell if that one goes into the 007 or not. It's that general area that has the oil residue.
    Thanks for any suggestions!!!!! I'm probably going to do the leak test tomorrow night.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Jun 26 2008
    austin, tx
    Re: Oil around diverter - PICS inside - help!
    I have this same exact issue.
    Looks like the valve cover gasket is seeping a little, but the hose that connects the diverter valve is nasty like in your picture.
    I'm experiencing a slightly rough idle and found this when investigating.
    crazy thing is some times I start my car and the engine is smooth as glass, other times it's vibrating pretty noticeably.
    It's diving me crazy...
    May 03 2008
    Orlando
    I don't have any vibrations or anything. The car is actually extremely smooth - can't even tell it's on when in neutral. Now I'm wondering if I'm imagining that I don't have as much pull/power because I might be driving more conservatively out of paranoia!
    I'm going to do the boost leak test in the next day or two. I had to get a coupler and ball valve for my air compressor tonight.
    I'm hoping there's a big ol' leak somewhere so that I'll actually have something to fix. Not knowing where all that crap is coming from is driving me nuts.
    When I installed the Forge DV I wiped that area down, but I didn't get that nasty hose. I'm going to go back under the car this weekend and see how much stuff came back over the last two weeks.
    Kevin W.
    Saint Cloud, Fl
    On 2003 and newer models the PCV on the back of the engine.
    You should look into doing this. I did it and it really cleans up the engine bay. Im gonna be helping Bwoy1981 do his here fairly soon.
    Time to also install a new VCG
    instagram ------------> low_enforcement
    May 03 2008
    Orlando
    I'd be interested in seeing you guys strip bwoy's bay. Maybe I could do my VCG at the same time.
    Kevin W.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    ahh man, thats nothin..i will be sure to get pics of mine 2moro, i wish mine looked like that...haha..goin to induktion next week to get some work done and probably BAT if all goes well....
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Saint Cloud, Fl
    yah that sounds good, I just gotta get Chris to order that block off plate
    May 03 2008
    Orlando
    Quote Originally Posted by 7speed View Post
    Forge makes one and they're local. Any difference?
    Kevin W.
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2005 Porsche 911 997 Manual, 2022 Hyundai Tuscon
    Orlando, Florida USA
    Ima get it Sam...sooon!
    Current: 2022 E-Tron Sportback Premium Plus, Siam Beige, S-Line, Black Optic Package, 22x10.5 Vossen HF'5's, 285/35/22 Continental DWS 06 PLUS
    TOY: 2005 Porsche 911 997 Carrara White / Black Interior 6 Speed manual, Aero Kit,
    BC Racing Coilovers, FABSpeed Exhaust, Headers & Intake, 991 GT3RS Reps "GOLD"
    Saint Cloud, Fl
    really I didnt know that Forge made one also
    May 03 2008
    Orlando
    Kevin W.
    Saint Cloud, Fl
    yah I just saw that. I paid 40.00 Shipped for mine from IE and waited a week for delivery.
