Results 1 to 31 of 31
    Senior Member Three Rings 4 black rings's Avatar
    Mar 11 2008
    West Menlo, California
    Smile S4 Recaros in an B7 A4
    First of all is it possible to put some S4 recaros in an A4? If so how much would it cost for the front and rear seats and where would you get them? I was looking for new ones?
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    Re: S4 Recaros in an B7 A4
    I have no idea if they fit or not.
    I would say your best bet to finding a pair is at a junk yard where someone totaled their ish.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    Yes, they will fit. I have seen people put them in B6 A4s and the B6 and B7 platforms are the same.
    Veteran Member Four Rings nadroj81's Avatar
    Feb 12 2004
    Albany
    Quote Originally Posted by 4Rings3Liters View Post
    yes and no. B7 have a bladder in the passanger seat which is needed so you don't get a airbag out light. Airbags won't go off if light is on. So technically you need b7 seats, unless you rip out the bladder, wireharness from your stock seats and swap them (not exactly easy).
    I had s4 recaros in my b7.
    May 20 2004
    More cars
    Never Land Ranch
    Yes they fit, but unless you can find some used it will be VERY EXPENSIVE if you try and buy some new! You don't buy the seats as one peice, they are purchased in sections!
    SEXICAN
    2013 Q5 3.0T-DD
    2002 Honda Civic
    AMD/EPL Tial 605 B5 S4 SOLD
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    There was a thread in the group buy section about recaro seats, check it out!
    Veteran Member Four Rings italian a4 1032's Avatar
    Oct 17 2007
    mass
    what color are you looking for?
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    pics?
    Mar 11 2008
    Quote Originally Posted by italainboy1032 View Post
    Almost any color black or black with white alcantera.
    Oct 17 2007
    mass
    a guy in the b6 forum was selling his but i think they were silver his name is maverick
    Veteran Member Four Rings slimmj0k3r's Avatar
    Jul 31 2005
    Arizona
    i think they got for a bit over 4000 new
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    For a B7 you need B7 Recaros otherwise you will throw a code as nandroj81 mentioned.
    Also sedan rear seats are different than Avant seats so be prepared to do a bit of seat back swapping in order to get it right.
    Recaros are hard to find, but if you do come across a set I suggest you grab them. One of the best mods you can do to the car if you love driving.
    I drove from Vancouver, BC to LA for mine.
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    Those do look really good.
    How much do they weigh compared to the stock seats?
    Veteran Member Three Rings Alkemix's Avatar
    Apr 23 2008
    2019 Lexus NX (wifes)
    I never really was feeling those S4 Recaro seats. They look like hunched up chubby chocolate men laying back in the car, but I'm sure that it will grab you through turns 10x better than the stock seats... that alone might be worth the swap if the price is good.
    Gone:
    2008 2.0T Quattro 6 MT Dolphin Grey / APR 91 / APR Catback / APR Intake / Sway Bars
    2013 S4 S-Tronic Black / Magnaflow / USS / STOCK
    Jun 11 2005
    Vancouver, BC
    They weigh quite a bit. Almost twice as much as the stock seats from what I remember.
    They might not look super cool but the back support for long distance driving is much better than the stock units. My back was killing me on the drive down to LA and I was in heaven coming back home.
    There might be better seats on the market but for an OEM plug and play solution these are as good as it gets.
    Apr 23 2008
    Yea, i feel the stock non-sline seats have as much lateral support as a desk chair.
    Are the S4 and RS4 Recaros the same?
    Gone:
    Jun 11 2005
    Vancouver, BC
    S4 and RS4 Recaros in NA are the same.
    Veteran Member Three Rings gyroscope's Avatar
    Mar 19 2007
    06 A4 S-Line Quattro, 98 K1200RS, 21 GTI SE DSG
    Queens, NY/Poconos, PA
    The RS4 uses the Recaro Sporter CS, and the S4 uses the Recaro Trend Topline. You can order the two fronts with sliders/brackets for less than 4k, but you will have the issue of the airbag light and you will also have to wire them into the harness/fusebox to retian power options. I cannot relay in words how angry I am that Audi never offered a Recaro option for S-Lines in North America. Everytime I hit a corner with the sport suspension myself and all my passengers slide out of the cheap non supportive oem seats.
    Senior Member Three Rings tdavit's Avatar
    Aug 27 2005
    CT, FL
    Quote Originally Posted by gyroscope View Post
    no you cannot wire the sportster cs into the fuse box to retain power. and the rs4 euro does not use sportster cs they are different they are not available thru recaro. the american rs4 uses the same seats as the s4 which are not topline seats almost all seats used as factory seats are not available from recaro you have to go thru the the dealer. i have sportster cs and they are super comfy and i am working on defeating the airbag lights to allow the airbags to work.
    Nov 15 2007
    do the S4 recaros have airbags?
    Jun 11 2005
    Vancouver, BC
    Quote Originally Posted by supamannn99 View Post
    Yes
    Senior Member Two Rings medracr's Avatar
    Mar 01 2004
    2006 A4 2.0T S-Line
    Los Angeles, State of Confusion
    The S4 OEM Recaros have airbags. The aftermarket Recaros do not. They do however have the wiring harnesses for electric and heater. Just got off the phone with Recaro NA, and best we can figure, the S4 uses the Style Topline, not the Trend. Compare pics and you will see the difference. They can be had for ~1700 each side. They were unable to tell me if the seats would bolt right up to our rails, and, if they don't, the rails run around 250 per side. Looking at about 4000 for the whole setup, which is much better, I assume than the stealership price. Hope that helps.
    Here's pics of the seats for comparison:
    Trend
    Style
    "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, Cuban cigar in one hand, martini in the other, body thoroughly used up, totally worn out and screaming 'WOOHOO! What a ride!' "
    -Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!- Jonan
    Aug 27 2005
    CT, FL
    no they dont bolt up to your rails you need brackets the electric unit for the topline is contained in the seat you need wedge brackets which bolt to the floor and then the seat bolts to the bracket.
    Mar 19 2007
    Quote Originally Posted by tdavit View Post
    I think you read through my post too quickly without fully understanding what I was saying. I never mentioned the European RS4, and you can buy the Sportster seats withy power options, however, the fashion in which you wire them is entirely up to you.
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Quote Originally Posted by medracr View Post
    Trend
    Style
    Image links aren't working, but I think the Trend is what I have:
    Only the Euro RS4s get the topline correct?
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Oct 01 2007
    Location, Location, Location
    want....those...seats.....
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    wow man too much money to spend.. but shit those are nice.. imight do different seats, but something more in my price range
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Aug 27 2005
    CT, FL
    the sport is available with power "topline" but the sportster is not available with power.
    i would know:
    Oct 01 2007
    Are those power seats? They look sweet, what model are those?
    Mar 11 2008
    BUMP!
    Aug 27 2005
    CT, FL
    speedster cs, they dont come with power option
