Results 1 to 9 of 9
    Senior Member Three Rings 04_A4_1.8T's Avatar
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    is there a diy for changing your taillight?
    so my driver side tailight has gone out and in the manual it says to have the dealer do it... i called and he quoted me 50 bucks for a freaking taillight!!!! There is no way that it is that technical of a thing that a normal human cant do it... i tried searching or a diy but came up blank?? has anyone done this that can walk me threw it? thanks in advance...
    Jun 08 2008
    Calgary AB Canada
    Re: is there a diy for changing your taillight?
    Pop your trunk, open the little covered hole, unscrew bolt (I think its a 7mm) and pull the taillight out
    Veteran Member Four Rings JerseyShoreA4's Avatar
    Jun 17 2007
    2013 B8.5 allroad (current) 2007 b7 a4 (previous) 2006 vw touareg (previous) 2003 b6 a4 (previous)
    Ummm the Jersey Shore
    philips head works too. the cover he's mentioned is the round looking lump right where the trunk lid meets the taillight basically. pop that open with your fingertips or a flathead and you can access the screw. there's only one holding it in. there are two plugs mounted to the headlight that plug into the quarter panel. Once the screw is out, it basically hinges on those plugs til they pop out of the quarterpanel. Hope that makes sense
    Miss my B6
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    my brake light went out, the dealer replaced it for 6 bucks, (the bulbs price), in 5 minutes
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    Quote Originally Posted by Charlescrs6 View Post
    your lucky... the guy i talked to said 50 but he had to go ask some one i think he was new maybe i just dont see how they can charge 50 bucks for that...
    Veteran Member Four Rings 02silverb6's Avatar
    Nov 20 2006
    ATL, GA
    Are u kidding!? 50 bucks? It takes 10 mins max. Pop the trunk, pop out the circular cover, unscrew the screw (its very long), pull the taillight out and do what u need, put it back together and your done. Pretty straight forward really.
    /thread
    PM me if you need RNS-E installed in Atlanta area
    R.I.P 2002 Audi A4 3.0
    Apr 13 2008
    04 Audi A4 1.8T
    Utah
    alright seems pretty easy.. i will go pick up the bulb and try it...
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    It's just about the easiest thing to do on your own. Give it a go! You'll be changing bulbs in no time!
    Oct 06 2008
    Faro
    50 bucks...thats BS. it should cost your $2 for bulb and 5 minutes of your time. Very easy. Check this out if it helps.
    http://a4mods.com/index.php?page=web...ges/tails.html
    Always check forums before getting any works done. This place is amazing with lots of brain power. I might have saved 100s of dollars by working on my car.
