Originally Posted by
rdguy
Blue it is. I tried disconnecting the 4 pin plug and running vag to clear the code, but cannot clear it. I plugged back in again and still get the code.
What was more interesting was in the "readiness" section, i have some readings that show FAILED OR INCOMPLETE for the following , Oxygen sensor heating, oxygen sensor, evaporative emissions and catalytic converter.
I now wonder if there is something else going on and not just the temp sensor?
The "incomplete" stuff is what's called "two trip logic". It may have seen a fault, but won't post a code/CEL/MIL until it sees the fault twice. "Failed" is pretty obvious, but I wouldn't worry about it until it actually brings up the code/CEL for that issue.
Are you running a test pipe or HFC?
Replace the temp sensor. It's a common issue, more so with the green connectors, but it's a cheap and easy way to start. DON'T forget to put a new o-ring on the coolant temp sensor. It should come with one, I forgot when I changed the coolant flange back there and it leaked everywhere for a min.
I figured it out real quick, just save yourself some grief.
