Originally Posted by
kingtr
But forge are spring type right? 710n is diaphragm. I thought diaphragm was preferred (as long as it can hold the boost). Forge etc is overkill, don't you agree?
the difference in response between the diaphram and piston type DV's is so negligable. you will never notice. probably .002 seconds..
and forge/dahlback/bailey/etc is not overkill. if you have too stiff of a spring in it, then maybe..
main reasons to go with an aftermarket piston valve is for 1)looks 2)differing sounds 3)differing recirc/atmospheric settings(forge splitter)
all in all, the 710, sounds pretty much like the rest. and will hold the boost up to BT applications. and they are cheap
