Results 1 to 18 of 18
    Apr 14 2008
    a4 avant
    marlboro
    doing caps right
    am i doing the fats thing right: first i got an 1.81 and then second with a different log 2.09...if i can figure out how post logs ill get them up...but im confused thanks for help in advance-ps dont think there right tho
    Sunday 14 September 2008 20:24:05
    8D0 907 557 N 1.8L TAPP93 MOTR HS D05
    Group A: '003 Group B: '032 Group C: '006
    Engine Air Throttle Ignition O2 Sens Learning O2 Sens Learning _ _ Engine Engine Intake Air Altitude Level
    TIME Speed Mass Flow Angle Timing TIME Val@Idle Val@Part Ld TIME Speed Load Temperature Correction
    135.12 3200 29.72 57.7 32.3 134.59 -7 0 134.87 3040 2.85 30 -0.8
    135.96 3680 36.73 61.6 31.5 135.4 -7 0 135.68 3480 3 30 -0.8
    136.77 4280 50.21 74.6 27.8 136.21 -7 0 136.5 4040 3.45 30 -0.8
    137.57 5080 81.25 80.3 19.5 137.03 -7 0 137.31 4760 4.6 30 -0.8
    138.37 6080 88.54 80.3 22.5 137.85 -7 0 138.11 5720 4.6 30 -0.8
    139.13 6920 93.47 80.3 26.3 138.63 -7 0 138.88 6640 4.4 30 -0.8
    -vrt-
    Feb 27 2005
    North Wales, PA
    Re: doing caps right
    You want to be in 3rd gear.
    Apr 14 2008
    a4 avant
    marlboro
    i believe those are third gear logs...frrom a while back tho so im not entirely sure, anyone know how to save a screen shot so i can post the whole logs...
    -vrt-
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    FAT's run in an A4 is not 4200-6500, since that is not 60-92 mph in our cars.
    YOu can save the screen by using "print screen" or using a image viewer like IrfanViewer that lets you capture a screen shot.
    That log shows 2.6125 CAPS time, so it is most likely a log of 2nd gear. Just dont see a 3500 lbs A4 making less then 400 to the ground doing a 3rd gear pull from 3200-7k rpm in 4.01 seconds.
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    1.81 fats? haha
    i think GURUMAN could pull that off
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jul 07 2004
    socal
    Quote Originally Posted by sean1.8t View Post
    1.81 fats? haha
    He couldn't even do that because the Twin GT S4's dont even hit full spool till 5k.
    Apr 14 2008
    a4 avant
    marlboro
    Idk but im pretty sure those were 3rd gear pulls but ill double check and post the logs wen i get home
    -vrt-
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    your back up already?
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Apr 14 2008
    a4 avant
    marlboro
    no these were from 2 weeks prior...next weekn ill b bak runnin n hopefully ready to go racn at sng
    -vrt-
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by GURUMAN View Post
    boost hits hard at 4600rpm till 8k
    and he's running low timing right now
    Current:
    Previous:
    Apr 14 2008
    a4 avant
    marlboro
    why can i not post attachments..i have the screen shots but cant get them up
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    heres one...it wont let me paste a screen shot on here so...
    and heres another
    Apr 14 2008
    a4 avant
    marlboro
    on a side note...is that normal only to get a 80.3% throttle angle
    -vrt-
    Feb 27 2005
    North Wales, PA
    you're still doing it wrong.
    do a WOT run from 3k rpm to redline in 3rd gear and log just block 03.
    then take a screen shot, paste it into microsoft paint, and save it as a jpeg. then upload the photo of the log onto a hosting service and post the picture.
    On a side note, you aren't pulling as many g's/sec of air on the ford maf as i would expect. I would move over 100g's/sec on my 3071r at 20 psi. Chris told me at 100g's/sec is about 300whp.
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by 1fstavant View Post
    its not % its degrees. I think i've peaked 87 degrees before on my aeb.
    on the dbw cars the throttle angle is measured in %
    Jul 07 2004
    socal
    Might want to actual look at your log seeing that it shows a deg mark under the throttle angle block.
    How much boost and have you actually driven it? Because I have driven a twin GT S4 that was making 650whp pushing 32psi and it had more lag then my A4.
    Apr 14 2008
    a4 avant
    marlboro
    so at 18lbs i have a caps time of roughly 3.94 right?
    -vrt-
    Jul 07 2004
    socal
    What log are you using, because I only see a 2nd and 3rd gear run with 3rd being 5000 and up.
