Results 1 to 11 of 11
    Senior Member Two Rings GermanAudi's Avatar
    Jun 01 2008
    2003 Audi A4 1.8T Multitronic
    San Diego, CA
    Sound cutting out on driver side speaker
    What I've been noticing recently is that every time I turn the radio on, sound only seems to be coming out of the passenger side, or the driver side speaker crackles with sound.
    The only workaround I have to this so far is to crank up the volume to 12-13, then the sound comes back.
    What might the issue be? Speaker? Wiring harness? How do I fix this?
    2003 1.8T Multitronic CVT, Canvas Beige Metallic
    GIAC Stage 1 || 710N TT Diverter Valve || 6000K Xenon HIDs || VMR Vent Boost Gauge || Eibach Pro/Bilstein Sport Suspension
    Senior Member Two Rings Audituning02's Avatar
    May 13 2008
    2002 A4 1.8T 5QM 00 Rover Discovery 2
    Maine
    Re: Sound cutting out on driver side speaker
    Bad or loose connection somewhere, if you can get the door panel off you may be able to clean the contact point on or at least see where your problem is coming from
    Audituning02
    Magnaflow : TP : tt 225 DV : Color Matched Lowers :
    Pearl Black Roof : USP Front : RS6 19s : Sport Suspension : Smoked Lamps : Dice Link : Black Out Grilles : 35% Tint : Rear Lip Spoiler : ZiZa Yellow Fogs : B6 S4 Front Brake's
    Jun 01 2008
    San Diego, CA
    How do I remove the door panel to clean the harnesses? DIY guide?
    Veteran Member Four Rings ApexIt's Avatar
    May 28 2008
    2005 A4
    just pop off the trim piece on the door and unscrew the screws that were under that trim piece. there is also a screw or two down by the armrest where you can pull the door shut. try checking out the DIY area of the forum and search for a window regulator/motor DIY since it requires removal of the door panel.
    Senior Member Two Rings Sammy7's Avatar
    May 03 2008
    2003 A4 Avant, 1985 320i Baur
    San Angelo, TX
    I have the exact same thing and it's really starting to tick me off. Unfortunately, I don't have time to fix it right now...
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    i think that problem might be where the door opens cuz my car does the same thing and when the door is open and u kinda tug on the rubber housing for the speaker wires it goes in and out.
    Dec 13 2007
    St Paul, MN
    Quote Originally Posted by Sammy7 View Post
    +1 on that for me too.
    It really ticks me off too.
    Deactivated Three Rings
    Apr 11 2008
    Quote Originally Posted by drmeegge View Post
    +2 dude, someone should really take the lead on this one and let us know their progress
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Here is one potential root cause. This is the problem with my car but I have yet to fix it.
    http://www.audigeeks.com/forums/inde...20761#msg20761
    and here
    http://www.audigeeks.com/forums/index.php?topic=2631.0
    -Doug
    Established Member Two Rings Quattro_USP's Avatar
    Apr 24 2008
    Kansas City, MO
    I also have the problem with my driver door speaker, but mine makes a whistle or whining noise that is consistant with the engine reving up or down. I have it disconnected for right now until I can find out how to fix it.
    Registered Member Two Rings
    Jun 08 2008
    Baltimore, MD
    +3... drives me nuts.
