This car is a 2006 Mercedez CLS 55 AMG. it has 18000 miles. the paint was in pretty good shape considering the car sits outside all day every day. This isn't a daily driver, but since it isn't garaged i wanted to go with a LSP that was going to last a while, so i went with 1Z Glanz wax.
The paint had a lot of RIDS, so i needed to do a 3-step polishing on this car. i spent a whole 3 DAYS on this car just to make it absolutely flawless.
thoughts on M95- i like it, it has a pretty good work time, but i found that it doesn't cut as much or finish down as fine as M105. Especially on this ceramic clear coat it was hard to correct the paint.
Exterior
-Wash
-P21s TAW pre-soak
-CG CWG
-white shMITT
-Wheels
-CG CWG
-P21s Wheel Cleaner Gel
-EZ detail brush
-Swissvax wheel brush
-OXO tire scrubber
-white shMITT
-ARO (tires)
-Wheel Wells
-Simple Green
-EZ detail Brush
Clay
-Special Yellow Clay (you know...)
-ONR lube
Engine
-P21s TAW
-Meguiar's Hyper Dressing
Polishing
-Exterior paint
-M95 via LC fast cut Wool @ 1500RPM
-M95 via Purple Foamed Wool @ 1500RPM
-Menzerna SIP via Orange CCS pad @ 1500RPM
-Menzerna PO85RD via Black CCS pad @ 1500RPM
-Makita 9227C
-3M backing plate
-1000w halogen lights
-ISA 50/50 wipedown
-Wheels
-1Z Chrome Polish
-Exhaust
-1Z chrome polish
-#0000 steel wool
LSP
-Exterior Paint
-1Z Glanz Wax
-FK1 # 425
-Wheels
-Swissvax Autobahn (2 coats)
-FK1 # 425
-Optimum opti-bond tire gel
-CG Barebones (wheel wells)
Extras
-Stoner's Invisible Glass
-1Z Glass Polish
-1Z Gummi Pflege
Interior
-CG Leather Cleaner
-1Z Cockpit Premium
-Zaino Z10
Before pictures. notice the hedlights were fogged up before i got there.
the Brake calipers were full of grime and brake dust. P21s Wheel gel took care of this problem!
look at how dirty the clay was! (don't mind the black rubber marks)
After Claying the entire car
Getting close to the end of day 2 on the job. After polishing with SIP.
