Originally Posted by
absolutegtr
Run with race gas and meth, so you can increase timng.....
also remove the spare tire, passenger seat and rear seats
race gas and meth is a huge waste of time. Better off running straight race fuel and increasing the timing.
audiminiac
Why go bigger turbo ? There are some guys here who tun 12,61 and 12,75 with simillar setup...
Yes but that could be all in the driving to get the better times and higher mph.
What are your rpm shift points for each gear?
Splattj
Your 60' and R/T look good. It seems you just need to make more power or loose some weight.
a 50hp shot of nitrous might do the trick, but who wants to use cheater gas?
Good R/T? You do know that a good light is .5-.6 seconds while his reaction times were well over 1 full second, that means he was still at the line when the green light came on. Anything above .7 is a bit slow.
