Results 1 to 13 of 13
Thread: Airbag light
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    Airbag light
    Dont hurt me, just tell me what I should do.
    Monday, 06 October 2008, 19:29:31
    VAG-COM Version: Release 409.1-US
    Control Module Part Number: 8D0 959 655 D
    Component and/or Version: Airbag 7 Audi 0302
    Software Coding: 00104
    Work Shop Code: WSC 06335
    1 Fault Found:
    01218 - Side Airbag Igniter: Passenger Side (N200)
    32-00 - Resistance too High
    How can I fix this?
    Every time I erase it, it comes back 1 second later.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Registered Member Two Rings
    Dec 09 2007
    Massachusetts
    Re: Airbag light
    move your passenger seat around... and clean the connection under the seat
    Mar 04 2008
    West linn, Oregon
    Re: Airbag light
    K thanks ill try that.
    1998 A4 sold
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: Airbag light
    buy a 4.7ohm resistor and plug it into the airbag connector and the light will go off
    Mar 04 2008
    West linn, Oregon
    Re: Airbag light
    Excuse my ignorance and laziness where is the airbag connector?
    1998 A4 sold
    Senior Member Three Rings A4Quattro > all's Avatar
    Sep 23 2008
    Wisconsin
    Re: Airbag light
    I am battling the same prob. right now as well.
    Quote Originally Posted by AudiRacerS4 View Post
    Where can you buy one of these?
    2004 A4 Quattro
    1.8t 6 Speed Manual
    Mar 04 2008
    West linn, Oregon
    Re: Airbag light
    Radio shack. And after searching I still have on idea where the airbag connector is.
    1998 A4 sold
    Mar 17 2008
    97 2.8 5spd quattro
    wa
    Re: Airbag light
    i have a similar problem, except i dont know whats setting off the airbag light, im gunna hope its a connection issue
    Established Member Two Rings Kaytek's Avatar
    Nov 19 2005
    Ottawa, Canada
    Re: Airbag light
    If you want that airbag to work then don't use a resistor. Here is a picture of the connection under the seat. Basically disconnect that pink/purple plug, clean the prongs with some brake/electrical cleaner (I used a Qtip soaked in cleaner to avoid making a mess) and stick it back together. I also used some hockey tape as opposed to a zip tie to make sure it stays properly connected. Nearly two years later, no airbag light.
    A word of warning is that I was paranoid and disconnected my battery before doing this. It may or may not be necessary but I took the precaution. Make sure you have your radio code if you do decide to disconnect the battery. Oh and you'll have to slide your seat out of the rails to get better access to the connection... that's the hardest part of this 'repair'.
    Cheers,
    Kaytek
    2001 1.8TQ Tip - GIAC X - Startup Racing Vogtland GTs
    Mar 04 2008
    West linn, Oregon
    Re: Airbag light
    Thanks man, but none of my air bags will work or just the passenger side with the resistor?
    1998 A4 sold
    Established Member Two Rings A4Gasm's Avatar
    Jan 24 2008
    98 Audi A4, 06 Suzuki GSXR600
    Boston Massachusetts
    Re: Airbag light
    same thing going on with my 98. when the giac dealer chipped me her vaged my car and got the resistance too high thing too. Although I think it was in both airbags. I wonder what would cause BOTH connectors to get dirty simultaneously...
    I'm gonna give this a try.
    98 A4 1.8TQtip
    Gpop K04 Hybrid / GIAC pump /3.0" magnaflow at the downpipe / Baily DV / AWE Vent Boost Gauge / 17" Gloss Black S4 AVUS / K&N in stock box / Smoked Side Markers / Debadged / 20% Tint / Kamie Grill / Facelift Tails with Foglight Mod / Blitz Dual Turbo Timer
    Buy my cd player and subs please http://www.audizine.com/classifieds/...ct=2353&cat=44
    Nov 19 2005
    Ottawa, Canada
    Re: Airbag light
    Rhinop21: Just the one with the resistor since it will be disconnected.
    A4Gasm: I don't think it has much to do with the connectors getting dirty, just that the connection becomes loose. I cleaned them for the heck of it, but likely just making the connection more secure, through zip-ties or tape, is what does the trick.
    Cheers,
    Kaytek
    Jan 24 2008
    Re: Airbag light
    Quote Originally Posted by Kaytek View Post
    Cheers,
    Kaytek
    Thanks, wish me luck
    98 A4 1.8TQtip
