Well if its below the hatched area on the dipstick then it is indeed low. If you have no leaks you could be burning oil....
My oil checking procedure:
1) Warm car up to full operating temp or do this after a 20+ minute drive.
2) Stop car, turn off engine, let sit for a few minutes for oil to drain to the pan (like 2-3 min)
3) Check oil level
4) Top off to about 3/4 up the hatching. When you put oil in, it needs time to drain down. Keep a record of exacty how much you add.
5) Recheck every week and determine your loss rate
6) If you have a significant loss and no leaks, send oil to lab for analysis and probably get a leak down test
7) Depending on results of the leak down test, the next step can vary. If its slow enough, you can just continue to top off.
To be frank, the simplest solution is usually the right one. DOUBLE CHECK for leaks, pull the belly pan and get a flashlight. Just b/c you dont see oil on your driveway doesnt mean there is not a leak and its not pooling on the pan. It could be as simple as a drain plug that is not tight enough or a bad crush washer that was reused. Check the top of the motor as well, around the valve cover and cam chain tensioner, etc. Anything heavier than a light dirty film means there is a leak.
