Results 1 to 8 of 8
    Veteran Member Three Rings mdma2004's Avatar
    Aug 24 2008
    GCC
    Lightbulb 02 A6 VS 03 RS6 tranny
    Hi everyone, I have a 02 A6 2.7T with Tiptronic tranny
    I heard from quite a few people that my tranny will not hold out too long if my car is gonna be stage 3
    My biggest dilemma is How does the same tranny which is by audi specs
    5speed HP24 automatic with tiptronic and DSP hold out RS6's 450 Hp, or what would i have to do, to work like the one in the RS6's
    thanks everyone...
    May 16 2008
    South Texas
    Re: 02 A6 VS 03 RS6 tranny
    Quote Originally Posted by mdma2004 View Post
    thanks everyone...
    Your car has the 5HP19, the 5HP24 was used on the V8 cars.
    Best option is to have your transmission modified by the people that do that stuff.
    Jan 26 2008
    Sydney
    Apparently the RS6 uses a special bellhousing and wont interchange with the 5HP24 from A6/S6 V8's, unless someone who knows 100% can clarify this as being false?
    May 16 2008
    South Texas
    That is correct the RS6 transmission will not bolt up to an non RS6 engine without extensive modification. The RS6 torque converter is alot larger than the V6/V8 torque converter, meaning a larger bell housing on the RS6.
    Jan 26 2008
    Sydney
    Would it be then that the RS6 uses the W12 bellhousing and torque convertor?
    May 16 2008
    South Texas
    Quote Originally Posted by RS-MAD View Post
    That is the rumor, but isn't the W12 a 6 speed? I havn't had an opportunity to get a W12 trans or anything at the shop.
    Jan 26 2008
    Sydney
    There was a 5HP24 used on the W12 and also the 6HP32 from what I can find on the internet.
    Aug 24 2008
    GCC
    wow, i dont think im gonna do that much work, cause gettin that tranny modified is very expensive, might as well sell the A6, and get the RS6, cause it will be cheaper to buy one, other than makin an A6 look and run like the RS6...
    ive talked to the techs at audi also, yeah, that tranny will not fit period, just cause of the layout underneath the car, and it will not fit that engine, they didnt specify why or anything, but they said there is a website, that builds trannys for A6...too expensive
