Results 1 to 38 of 38
    Apr 14 2008
    a4 avant
    marlboro
    pics of the destruction
    as some of you know, i recently got to drop one of my exhaust valves into cyl 4 and well the outcome was not great but not bad the cylinder wall didnt get destroyed so i was able to save some money in labor and time...but heres what a valve will do to your car if it breaks....
    this lil fer did all this damage:
    -vrt-
    Jun 01 2008
    Apopka, FL
    Re: pics of the destruction
    o...m...g
    how long did the engine run after it droped?
    Apr 14 2008
    a4 avant
    marlboro
    about 20 seconds
    -vrt-
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    W.O.W.!
    new motor. that thing is done. Sorry
    Aug 13 2008
    Indiana
    no new head and full rebuild...
    Apr 14 2008
    a4 avant
    marlboro
    already in progress...only downfall no 2.0 too broke from building it originally
    -vrt-
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Seen that too many times... Pay for the exhaust valves or pay more for them later
    Sure youve learned, hopefully people will learn from you and switch from the sodium filled valves if they want to make real power
    Jan 25 2006
    A4 2.0T
    MD
    Best carnage pics I seen in a while...
    thanks for the pics.... I feared this would happen to me for a long time.
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    So how does this happen again?
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Feb 17 2005
    Sarasota, FL
    Holy hell! Good luck with the rebuild
    Veteran Member Four Rings the_pirate's Avatar
    Apr 08 2008
    Houston
    ewww dats nasty! good luck!
    History:
    2001 A4 1.8t manual swapped
    2007 GMC Sierra ext cab
    2002 Chevy Tahoe Z71
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Don Supreme View Post
    No doubt, we should make a carnage thread lol
    - Clint
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Quote Originally Posted by 1fstavant View Post
    sucks,i was too broke also when my timing belt broke so i got a new head and oem rebuild. But at least you'll basically have a new motor.........im only 30.000 miles after my full rebuild.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Veteran Member Four Rings dualaudi's Avatar
    Dec 13 2004
    allroad 2.7t
    san diego
    Quote Originally Posted by PiMPMAN101 View Post
    ^x2
    This exact thing happened to me when my belt dropped 3-4 teeth. Was it the belt or do our valves just dropped once in a while.
    (just saw your other post 370hp...) wow...
    (sold) 1999.5tqm :: gtrs, atp 3"TP, tweaked mika t3/t4 8k, adj. fpr, forge 004, MBC, neuspeed: catback exhaust, E-bay special FMIC! 9"x28"x2.75" - SOLD
    https://www.instagram.com/dualaudi/
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by boostedup View Post
    Should have put some scat rods in there.
    Apr 14 2008
    a4 avant
    marlboro
    well basically what i think happend was a misshift resulted in valve float and when the valve came down it bent and eventually just snaped off the valve stem...but idk thats my theory could have just been age and heat
    -vrt-
    Registered Member Four Rings
    Jun 14 2007
    2007 A4 2.0T QM 2008 A8L
    New York
    The horrors of owning a manual.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    omfg, was the valve "pinging" around in there, I mean, could you hear it? Im terrified to remove my head tonight...so the cylinder walls were ok? it only took 20 seconds to do that, how were you driving it when it happened?
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    holeeeeee chit
    good luck with that
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Guess ill be putting some better valves in my motor when I build her!
    Apr 14 2008
    a4 avant
    marlboro
    euro...the worst part was that i wasnt even getting on it maybe 2to3k and all i heard till the motor stoped was a metallic clanking...clank clank clank type deal
    -vrt-
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    i went with incollnel (spelling) exhaust valves that I got from mike2ptzero. only issue ive had so far is the damn guide seals are leaking causing oil consumption. that will be fixed soon so i can really start beating on this engine, not like i havent already... mwahahahahaha
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Veteran Member Three Rings aaronamerica's Avatar
    May 31 2005
    Dallas
    this samething happened to me long time ago, my timing belt tensioner failed
    1998 Audi A4 built 1.8t Quattro--MaxxEcu Standalone---ID1300cc injectors ---Gt3582 turbo---on E85 --- AEM fuel pump---
    2003 Audi Avant built bottom end 1.8t Quattro 5speed--Eurodyne Maestro---gt35 turbo--- On E85--- 870cc injectors--Walbro 450 fuel pump--19" Staggered iForged Daytona wheels
    2011 Audi Q5 Daily--H&R springs--Eurodyne Stage 1 tune
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Word.
    I got some to add. No engine carnage though. I doubt we could get it stickied, but it would be good to keep around.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by djwimbo View Post
    Word.
    lol I got some clutch carnage ill post up from this guys clutch I did today
    - Clint
    Apr 14 2008
    a4 avant
    marlboro
    some of the new build again...
    new pistons vrs old:
    fmic without bumper:
    and the crank:
    ran into a slight problem with the mahle pistons, they were hitting the oil squirters so there at qed getting clearanced to fit...should have more pics by next week
    -vrt-
    Senior Member Three Rings A4Quattro > all's Avatar
    Sep 23 2008
    Wisconsin
    Damn. That's distruction all right.
    2004 A4 Quattro
    1.8t 6 Speed Manual
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I've got pics of what appears to be broken cams in a 1.8T due to oil sludge problems. Which reminds me. I need to contact that guy and get some more pics and proof that the cams did separate in two (or what probably happened was the bearing caps sheared and broke).
    Quote Originally Posted by 317ssayzarc View Post
    Thank you for that information. Makes me so happy I listened and put Inconel exhaust valves in my cylinder head.
    -Doug
    Apr 14 2008
    a4 avant
    marlboro
    mahle pistons not going in...got a set of tt225 pistons bob said there roughly a 8.7:1 cr but advertised as 9.0:1, along with the msibc from gizzmo, and all new brakes so i can actually stop alittle faster -still stock just slotted and drilled... so the car should be done with in the week or mid next week
    ::crosses finger::
    then breaking it in and if im lucky running at etown the 19th....or a dyno day
    -vrt-
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    That is going to be sick whats the new numbers you shooting for
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Apr 14 2008
    a4 avant
    marlboro
    what ever it makes...wont find out till i get to a dyno love to see 400+ but who knows
    -vrt-
    Jan 25 2006
    A4 2.0T
    MD
    ::crosses finger::
    I have a set of those pistons in my motor right now.
    Jan 25 2006
    A4 2.0T
    MD
    A real dyno this time...
    P.S. You aren't changing anything to make more power, just taking care of some possible failure points and lowering compression so you can avoid some detonation....
    You need some head tricks for more power or another turbo.
    Apr 14 2008
    a4 avant
    marlboro
    yea i know...shoulda went 2.0 ...i realize i wont be making any more power besides reving alil faster due to lighter components...however i still hold my view that the dyno was low reading so once again hopefully 4
    --but yes a real dyno either ams or one right in ossining
    -vrt-
    Jan 25 2006
    A4 2.0T
    MD
    I might have missed it, what lighter components besides the pistons? Are you doing a TI retainer setup?
    Apr 14 2008
    a4 avant
    marlboro
    supertech intake and exhaust valves(standard size), cat springs, rosten retainers
    -vrt-
    Jan 25 2006
    A4 2.0T
    MD
    OK, so Ti retainers, that other stuff isn't really any lighter, but yeah... I just hope the 50 trim on stock cam can flow @ 8k.
    Apr 14 2008
    a4 avant
    marlboro
    you and me both...cams may be in the work tho if i can get this vr6 back into my car without assistance from a shop...500 extra and thats some eurospec cams-also any info on these
    -vrt-
