Results 1 to 6 of 6
Thread: Cabin Heat
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Cabin Heat
    I've seen couple of people mention this but there were no real answers and I only found one thread in A4 forum about it which didn't lead anywhere.
    Just driving around with heat off (still hot outside) and there is a lot of heat coming into the cabin through the vents under the steering wheel. On other vehicles I've had before (VW mostly) there is a switch to stop the outside from circulating in. Is there no option on S4 to do this? I'm tolerant of heat but this can get pretty hot. Especially long drives to shows if I am wearing jeans.
    And no, I will not run air conditioning
    Feb 26 2008
    b7s4
    Re: Cabin Heat
    turn your HVAC on and scroll the temperature settings down to "low", turn the setting to "econ" and this will be the coldest air you can get in the cabin without turning on the a/c... then turn the entire thing off.
    why are you scared to use the a/c? on the highway the a/c is more fuel efficient than rolling the windows down due to the reduced drag.
    for best fuel economy @ highway speed: no a/c and all windows closed> a/c on with windows closed > a/c off and windows open > a/c on and windows open
    Mar 24 2008
    khgkhg
    Re: Cabin Heat
    Thanks, I'll try that. I don't like using AC. Not concerned with gas mileage. Just feel way better to drive with windows rolled down. Besides AC bothers my eyes.
    Senior Member Two Rings B6_Rakete's Avatar
    Apr 17 2008
    '04 S4 Avant 6sp, '06 330i 6sp
    Re: Cabin Heat
    Quote Originally Posted by 40valve View Post
    I notice the same thing one or twice a week. I live in the SF Bay Area which isn't always ridiculously hot and sometimes the temp coming out of the vents is 5-10 degrees higher than the ambient temperature outside. The only way I've found to get temp down to normal is to kick on the A/C for a minute and then hit "Econ" again. It really feels like the heater is on sometimes and I'm guessing there's an issue with the climate control programming.
    Apr 17 2008
    Re: Cabin Heat
    Quote Originally Posted by Swanky View Post
    I don't buy that 1980's explanation. Opening the moon roof and turning on just the fan (leaving the A/C off) seems to return the best gas mileage for me. Running with A/C on in my car drops the fuel economy by 1-2MPG, easy.
    Apr 17 2008
    Re: Cabin Heat
    Same deal with me, something to do with the dryness of the air.
