Results 1 to 19 of 19
    Veteran Member Three Rings drunknmunky408's Avatar
    Sep 26 2006
    2001 A4 1.8T FWD - SOLD
    San Jose, CA
    Clutch catch point is high
    My clutch catch point is really high... its all the way at the top at the release point. Is my clutch on its way out? If so, what should I replace it with?
    2001.5 Nogaro Blue S4 6spMT l Sports Package l Blue Alcantara Seats l APR Chip l Neuspeed Exhaust l Eclipse AVN6620 l AWE Boost Guage l AWE Pedals l NRG 230g Shift Knob l
    TEAM|AXION
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: Clutch catch point is high
    It's fine.
    Sep 26 2006
    San Jose, CA
    Quote Originally Posted by ILoveT View Post
    It's fine.
    its all the way at the top... i've had this car for 2yrs now and at times, i still stall! on my dads, its really low. even my buddy with a b5s4 stalled
    TEAM|AXION
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    There are a couple threads discussing this. Most of them confirm that the clutch engagement point is high.
    Veteran Member Four Rings 00SantorinS4's Avatar
    Oct 02 2006
    So. Maine
    I've had four audis. 3 b5's and 1 B6
    All of which the clutch engaged high.
    your car is fine
    2017 Audi S3//Navarra Blue//Black Optic//SuperSports//Tech//Dynamic//B&O//Injen Evo CAI//CTS Inlet//APR Coils
    Oct 01 2008
    Philly
    both of my B5s did this i always just figured i would need a clutch soon, never replaced it in my previous one, but probably will in my current B5
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    mine is annoyingly high also. Some say its due to clutch wear, but I've had 2 B5's and they were both this way.
    Dec 08 2006
    Cincinnati
    Quote Originally Posted by audiness View Post
    Yup, same. 2 B5's and I've replaced the clutch in BOTH. Engagement height exact same after replacement. If you still think clutch is on its way out do the 4th/5th gear test. (low speed 40ish put it in 4th/5th and floor it. If clutch holds you are good, if on its way out it should slip)
    Sep 26 2006
    San Jose, CA
    Thanks for all the info. It just pisses me off! 1/2in from the top is my catch point. is any of your guys car like this?
    TEAM|AXION
    Veteran Member Three Rings jojoampt's Avatar
    Jan 19 2008
    02' A4 Avant, 1.8T QM, 08' S-Line A3 MT
    Humboldt County
    mine is, (its a B6) but yeah, i can depress mine like 1 inch and shift
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Same here. Pedal height is high as hell ever since i bought it. as long as you aren't slipping you are fine. my clutch is starting to go but that's because its slipping during.....enthusiastic shifts....
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    you can see where i slip mine here; it's basically at the top
    http://www.youtube.com/watch?v=TcHNAAP47AU
    Dec 08 2006
    Cincinnati
    same...
    Jun 13 2007
    2005.5 A4 2.0T 6MT
    Leesburg, VA
    Same here, it took a bit getting used to
    2000 A4 1.8TQM Ebony Pearl
    210K on the Clock and going...
    2005.5 A4 2.0T Quattro 6MT Moro Blue
    Heated seats. Winter calls.
    Future Plans
    B8.5 S5... at some point... or a Cayman.
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    x1000..........
    i always thought it was my clutch going. its not.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Nov 09 2007
    Si,NY
    130K miles and my stock clutch is fine. Catches high as a mofo though, but doesn't slip.
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    same. My clutch point catches at probably an inch away from the top. It was really hard to get used to but now i got it no problem after some months practice. The annoying thing is, is that its so different from normal clutches that nobody can drive my damn car. I dont let any of my friends try ever again because the first time they drove it i felt they were gunna stall my car over and over or just burn it up! My only friend that could drive it was one that was used to Porsche clutches, iv heard they are very similar.
    but anyway yea, i test drove a b6 and it seemed to be very similar, maybe a little lower then my b5. BTW 121k miles stock clutch
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Dec 04 2007
    New York, NY
    I changed out my stock clutch at 96k miles and even with the new one the catch point is still high.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    my b6 is the same as is my friends b7.
    My theory is that audi designed in the high engagement point to allow for the engine to spool up a bit when going from a stop. i think it is an intentional feature for a turbo engine.
    are the 2.8/3.0/3.2 clutches the same? actually, don't they use the same clutch? if so it's probably the same.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
