Results 1 to 19 of 19
    Sep 30 2008
    Honolulu
    WFT? Please help if possible!
    I'm driving home today and out of nowhere my check engine light starts flashing. The car was still driving normal but the I was about 10 minutes from home.
    As I come to the last few stops by my house (shortly after the light starts flashing) I'm noticing that it is idleing rough at slow speeds. It still drives and accelerates kinda normally, but just with a slight hesitation.
    When I pull into my drive way and actually listen to the engine, it sounds like it's gonna fall apart. A loud noise coming from the engine compartment.
    I pop the hood and I can tell if the noise is coming from a pulley or from inside the engine!
    No other light came on in the dash and the gauges all read normal.
    Can any of you give me any advice as to what this might be?
    Established Member Two Rings THM's Avatar
    Jun 06 2007
    Audi A6 4.2
    Chicago
    Re: WFT? Please help if possible!
    scan with vag com
    might be spark plugs, coils ....
    2000 a6 4.2
    Established Member Two Rings utripn's Avatar
    Jul 13 2007
    2006 Audi A6 4.2 S-line
    Mission Viejo
    dont trip, its a coil.... pull out the coils 1 at a time and when you get to the 1 that does not change anything, its the coil you will need to change. coils are like 40 bucks. have fun
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by utripn View Post
    X2. Definitely sounds like a bad coil.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Sep 30 2008
    Honolulu
    Thank you guys for the help! I'm really hoping that's the problem! So I'm assuming that the coils are the three that are located in the front of the engine that the plug wires run into right? I'll just go and unplug each wire one at a time until I reach the one that doesn't make a difference.
    But would a bad coil cause that kind of noise to come out of my engine?
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    yes.
    2004 Audi A6 2.7T
    Jul 13 2007
    Mission Viejo
    make your car seem like its going fall apart, and check engine light comes on too! it sucks, you should have one in your glove as a spare, because they go bad alot.
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    LOL!!! I remember, when my first coil pack blew in my S4. I swore I blew my engine, or the timing belt let go at the time it started, just about crapped myself. Always keep a spare in the trunk, you never know when one will go.
    Good Luck
    Jul 13 2007
    Mission Viejo
    thats hilarious, i threw a tantrum and almost had a heart attack!!
    Sep 30 2008
    Honolulu
    Thank you again guys, I really appreciate it!
    Well I don;t think it's a coil pack, I pulled the wire closest to the engine from each pack, one at a time. In all instances, the engine idle (although really rough alreay) seemed to get slightly worse. Also, as I moved the wire back to place it onto the coil, a strong spark arc'ed each time which leads me to beleive that they are functioning correctly.
    I went down to Sear's and bought a handheld scanner to pull the codes. Here's what I have:
    P0341 : Camshaft position sensor A circuit range/performance (bank 1 or single)
    P0300 : Random misfire detected
    P0301 : Cylinder 1 misfire detected
    P0303 : Cylinder 3 misfire detected
    P0302 : Cylinder 2 misfire detected
    Does this help at all?
    Oct 09 2006
    Well P0301, P0302, P0303, all most likely are coil packs. I had three blow on me after I went stage 3 on my S4, and put in a new tune, so it is possible. Not sure about P0341
    Jul 13 2007
    Mission Viejo
    dont panic its still not a big deal, i would take it to a audi mechanic and have him diagnose it again. maybe 1 of your sensors is probably bad.
    Jul 13 2007
    Mission Viejo
    Jul 13 2007
    Mission Viejo
    how many miles you have on that thing??
    Sep 30 2008
    Honolulu
    61k miles. Thank you again!
    I just read the link you pasted. In the last posters remarks, he refer's to the "CMP". Is that the cam positioning sensor or something else?
    Quote Originally Posted by Daft View Post
    You have to look closer at the codes he posted:
    P0341 = Bank1 Cam Position Sensor (G40).
    P0301-Cyl.1 Misfire Detected (bank1)
    P0302-Cyl.2 Misfire Detected (bank1)
    P0303-Cyl.3 Misfire Detected (bank1)
    All of these codes are directly related. If the CMP is off, the plugs will misfire on that bank. Bank1 is Cylinders 1-3. This also will prevent the car from running.
    P0300-Random/Multiple Cylinder Misfire Detected is indicating that more than one cylinder is misfiring.
    P1113 is not related and says that the bank 1 primary O2 sensor's heater was not operating properly. The car would still run this way.
    P1347 is saying that Bank2's cam sensor is seeing an out of sequence situation. This is related to Bank1's bad CMP readings.
    Jul 13 2007
    Mission Viejo
    its the camshaft position sensor, have that looked at.
    Sep 30 2008
    Honolulu
    I think I'm going over to Audi to poick one up tomorrow. I'll just replace it as I'd rather not tow it all the way down there and have it sit for a week (that's how long it will take to see my car).
    I hope this works!
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    small possibility that it is the coolant temp sensor...
    any fluids dripping?
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Sep 30 2008
    Honolulu
    Not that I've seen.
    I do wonder however. I replaced the vacuum hoses and the suction jet pump 2 days ago. It had run fine since I did it, but do you guys think that something could have gone wrong with that?
