Results 1 to 9 of 9
    Veteran Member Four Rings pit viper's Avatar
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    rear bumper with cutouts?
    I'm not a big fan of the "stealth" rear bumper with downturns on the exhausts.
    I see a lot of A6 pics on here where the bumper has exhaust cut-outs. Did certain years/engines come with that?
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    Re: rear bumper with cutouts?
    02+ are 'cut out'
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Quote Originally Posted by oc-drop View Post
    02+ are 'cut out'
    Any other changes, or can I bolt an 02+ bumper straight up to my 00 car?
    I know they changed the front, but as near as I can tell the back stayed pretty much the same.
    Nov 20 2005
    I believe it bolts right up, you might also need this plastic part that looks like maybe a wind deflector? Like a plastic under belly for the rear.
    I ended up cutting my bumper here's a good pic
    is it 4:20 yet?
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    Looks pretty nice. Did you use a heat gun to flex the bumper out a little around the exhaust?
    Nov 20 2005
    no, just cut away
    is it 4:20 yet?
    Sep 25 2008
    2000 A6 2.7
    Phoenix, AZ
    I guess it's the reflection off the tips that makes it look like it's flexed.
    Registered Member Three Rings projectdarka4's Avatar
    Jun 08 2007
    2000 a6 2.7t tip
    illinois
    you can cut yours out with any tool of choice. I used a dremel.. then the best idea, which is what i did, was to go to any auto store, and pick up some black door edge protector that looks like a V.. put that on where the edges are and it looks really good. ill get some pics when i have a chance to see my car next week
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    I thought same as pit viper when I first looked. I understand a lot of folks have done this -- OC you didn't leave much gap. Looksnice. This has been something I've been debating for some time. I've developed a strong preference for one or the other that comes and goes....
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
