I just got back from a long trip (2500 miles) and during that trip, I was having some problems. Before leaving I installed a K&N filter, not sure if that has anything to do with it though. The check engine light came on so I stopped at the nearest parts store to get it scanned. It came up with a MAF code so I bought some cleaner and had them clear the code, in hopes that it would solve the problem. After spraying the cleaner in the MAF, I had trouble starting the car and assumed it was because the cleaner hasn't fully evaporated. So I waited about 5 minutes and it eventually started and ran fine with no code. Two or three days later, the light came back on with the same problem so I got it cleared again and hasn't come on since. Another symptom is, when I would start the car, sometimes it would just die immediately but start right back after attempting to start again. Yet another symptom, when I would get to my destination and put it in park, it would idle erratically. It would go from idle to around 1200-1500 RPM then drop back down and sort of surge then it would stop. It seems more like a TPS to me but the car is saying MAF. Any thoughts? Thanks a lot!
