Results 1 to 15 of 15
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    E-brake questions
    am trying to remove the E-brake cable that seets on the lower control arm at the rear of the car.
    the thing is, there is a rubber grommet not letting it pass thru holes that are in the lower control arm. i don't want to cut the grommet or file it cuz i want to reuse it.
    am i going the right way at tackling this or there is another way.
    i'll post some pics if need be for some.
    Thanx- Til
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    Re: E-brake questions
    i've heard some people had to cut the old cable in the middle and pull out from both ends.
    just not sure how they got the new cable in though. can't remember
    Nov 14 2006
    Land of the Eagles
    Quote Originally Posted by dingguhlbary View Post
    i dont want to cut the cable am trying to make my work easier
    even at that, i dunno where to get another cable and how much work is to replace it.
    Nov 14 2006
    Land of the Eagles
    Nov 14 2006
    Land of the Eagles
    i want to pull that cable in direction that the arrow is pointing
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    you have to remove the cable end from the caliper
    Nov 14 2006
    Land of the Eagles
    Quote Originally Posted by offroader1006 View Post
    that i have done.. it just that grommet it doesn't fit on that hole
    Nov 14 2006
    Land of the Eagles
    bump
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    i think ur going to have to cut the grommet diagnolly and it off that way
    2014 Audi S4 DSG
    Veteran Member Four Rings hoganalley's Avatar
    Feb 23 2007
    Burlington
    I just did this this weekend. Once I unclipped the plastic lock, the whole brake cable slid out no problem. The star shaped rubber part didn't give me any problem at all. The only problem I had was trying to unclip the plastic lock.....oh, and trying to get the passenger side out from around the rear diff mount. What about a silicone lube or something along those lines.....
    05 allroad 2.7T Stock
    99.5 A4 1.8T K04 - Sold
    Nov 14 2006
    Land of the Eagles
    Quote Originally Posted by bronz View Post
    hmm can u explain a little more.
    Nov 14 2006
    Land of the Eagles
    Quote Originally Posted by hoganalley View Post
    which plastic lock, and how u unclipp it? haven't tried any lube, but will give it a shot tomorrow
    Feb 23 2007
    Burlington
    You know what......I was looking more at your pic. Is this on the driver's side? Because if I'm correct, you're trying to pull the cable out the wrong way.
    If I'm right, the black washer looking thing at the bottom right of your picture was clipped into your lower control arm. If you have that unclipped, the cable should slide out the other way you have it illustrated......
    Nov 14 2006
    Land of the Eagles
    it won't slide out since the cables are connected to the brake box, where obviously the hand brake is.
    Feb 23 2007
    Burlington
    ok. If you've already disconnected the cable from the caliper, then the only way to get it out is to slide it towards the rear of the car and you have to have the cable disconnected from the e brake handle. There isn't enough slack in these lines to pull them out without taking it all apart. Also, the cable CAN'T come out towards the front of the car, has to be towards the back.
    What are you trying to do? If it's the passenger side cable, I couldn't get it off my car without cutting it.....
