Results 1 to 2 of 2
    Sep 30 2008
    Boost Leak Testing Help
    I was trying to check for a boost leak this past weekend using the method in the website
    http://a4mods.com/index.php?page=web...boostleak.html
    I plugged the hole for the PCV return line.
    When i started adding pressure to the system, i could hear what sounded like air passing through the oil (causing a sort of bubbling sound).
    I had no idea if this was suppose to happen, so i immediately stopped and put everything back together.
    You may ask why i am checking for a leak, well its because i just purchased the car and already fixed 2 vacuum leaks. Id like to be sure there is no other air leaks.
    So if anyone has done a boost leak test, can you tell me if this is a normal sound.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: Boost Leak Testing Help
    Quote Originally Posted by cripti0n View Post
    Completely normal. I got that noise every time I try a boost leak test using the TIP. If you want to avoid the noise then start the boost leak test after the turbo but it's no big deal if it bubbles so I wouldn't bother.
