Results 1 to 10 of 10
    Established Member Two Rings Rane_kn's Avatar
    Jan 12 2008
    Orlando, FL
    Exclamation She left me stranded again!....HELP ASAP!
    last night I went to start my car after work and she turned over fine, but less then 3-4 secs I went to put it in gear and it stalled. I thought, having had a few drinks, that it was me but when I go start it again nothing happened. I had 3 people try to jump my car but no electrnics turned on at all, not even my alarm or key lock. I just changed my alternator and the battery is fine. My mechanic said it might be the main fuse. He said there was a fuse in line with a wire from the battery to the ecu. I have the panel off but dont know which one he's talking about. can someone help me find the main ignition fuse or if this is even the right direction to take?
    "Shit Happens Wear a Diaper"
    Registered Member Two Rings
    May 02 2008
    B5 S4...Nogaro cuz its faster
    DC
    Re: She left me stranded again!....HELP ASAP!
    Theres also a fuse box under the hood...are you looking at the right one?
    i'm assuming your looking at the one on the side of your dash where the door closes?
    i really don't know much about electrical but check both.
    Jan 12 2008
    Orlando, FL
    Im also looking at the fuses under the steering column but i cant find the one under the hood wheres that?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by alosh View Post
    Under hood fuse box? You talking about the relay panel under the knee bolster?
    08 S4- Stock SOLD
    Jan 12 2008
    Orlando, FL
    i got it, i didnt think there was one under the hood the only ones i knew of where the on under the knee bolster and the one on the side of the panel. I just wasn't sure of myself. It turned out to be a loose bolt! the bolt that i tapped my gauge into was loose and it caused the whole system to trip...weird
    Jan 29 2007
    08 S4 00 S4
    MD
    Glad you figured it out
    08 S4- Stock SOLD
    Oct 29 2005
    10speed
    San Francisco, CA
    your car knew you were drinking, Audis are that good
    - Clint
    Jun 14 2007
    2000 S4
    Connecticut
    haha, .
    Veteran Member Three Rings IamEzraM's Avatar
    Jul 21 2005
    2001.5 Audi S4 Santorin
    Bedford/MA
    knee bolster = kick plate
    My car is fast
    Jul 21 2005
    Bedford/MA
    *kick panel (doh)
    My car is fast
