Results 1 to 4 of 4
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Factory manifold question
    Looking at the factory manifolds, they appear to have a anti-reversion design. In the quest to achieve more HP/TQ, wouldn't the anti-reversion hamper flow and /or velocity? Has anyone ported the inlet of the manifold to remove the anti-reversion area and achieved any gains that you can report on a dyno?
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Re: Factory manifold question
    Vast might be able to help, I belive they mod them and resell them
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Thanks. I was aware of their port work, but was curious as to what exactly are they porting? Besides the anti-reversion area, was is actually left to port? There isn't much material around the turbo outlet area to port, and it's probably best to stay away from the EGT threaded area so I'm trying to find out if it's really worth a shot.
    2001.5 Audi S4 VRT
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    MTM sell a cast performace manifolds that is a option for you instead of getting the tubeular ones for the exhaust as well, knowing MTM it is big $ but there stuff is quality
