Results 1 to 15 of 15
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    Is something collapsing under boost???
    Got the +1 about 3 weeks ago and i noticed a small issue right away. I wanted to wait a few weeks before asking you guys hoping it would correct itself or i would figure it out.
    At WOT in 1st gear (only in 1st), the car would experience ONE shudder/pause/choke at exactly 3800 rpm, then take off (well, as fast as a 1+ could ). Bottomline is, the car has a pronounced pause in accleration just as full boost is achieved.
    It feels like something is collapsing under boost. I have a NEUSPEED Xtreme TIP so i'm pretty sure that's not it.
    So, what is the next step? Samco Silicon hoses?
    Note: If i go about 85% throttle, then punch it around the same rpm (3500-3800), this does not happen.
    TIA!
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Senior Member Three Rings XdelaforceX's Avatar
    Jan 22 2007
    2006 C55 AMG, 2006 Harley Davidson Deluxe
    Arlington, VA
    Re: You think something is collapsing under boost???
    you may have a hole or tear in your TIP. i experienced the exact same thing, and it was because of a tear in my TIP, replaced it, and everything was hunky dory. this also caused me to lose 2 coil-packs as well, so after you replace it, you might look at replacing some of those as well. but my bet would be your TIP is bad, or not sealed, or has a hole...etc.
    X-eric-X
    |AMG|
    Veteran Member Three Rings ehfour's Avatar
    Feb 19 2005
    2002 A4 1.8T
    Vancouver
    Heatsoak
    Oct 29 2006
    Vancouver
    Quote Originally Posted by XdelaforceX View Post
    X-eric-X
    Hmm, a TIP tear causing a complete halt in acceleration. I'm trying to see how that would cause this type of effect.
    I should have mentioned that this abrupt halt in accel is very acute, it's only a split second, then the car shoots forward. It could be described as 1 "Hard Buck".
    Quote Originally Posted by ehfour View Post
    Heatsoak
    This would happen on my first (and every) pull, so I don' think it's the heatsoak, thanks though
    Another silver B6
    Feb 19 2005
    2002 A4 1.8T
    Vancouver
    Quote Originally Posted by BNZ TOY View Post
    Hmm interesting
    I have exactly the same mods as you + An apikol SMIC - the TIP
    and Ive never had any "Shudder" or "Pause" during full WOT in 1st - 5th
    Maybe its time to do some logging with the VAG...Seems like the car is pulling some timing
    Oct 29 2006
    Vancouver
    Hmm interesting
    The guys at RPI said it could be a misfire, so i'll get them to Vag Com it asap. Thanks guys
    Another silver B6
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    Re: Is something collapsing under boost???
    I used to have a similar problem too...then i got a FMIC and now its all good.. i am guessing heatsoak.. Does it usally happen on hot days?
    another stereotypical Audi
    Oct 29 2006
    Vancouver
    Quote Originally Posted by a4wd View Post
    Hot days? I'm in Vancouver, we have cold and arctic .
    J/k, I doubt it's a heatsoak issue for now since this happens even on my first pull after start, and every pull after.
    Another silver B6
    Jan 22 2007
    Arlington, VA
    yup, thats exactly what i experience, its thru acceleration, as soon as i hit 3800rpm/full boost, it felt like it stuttered for just a brief moment, almost felt like a misfire, and then would keep going.
    X-eric-X
    |AMG|
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    OP, try a hose clamp or two around the TIP. It will help to keep it's shape and not
    collapse under boost.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    My car with a software flash was collapsing the TIP around 5500rpm.
    -Doug
    Oct 29 2006
    Vancouver
    Man... I thought the Neuspeed one was the best, it sure demands a price that would make one expect the best!
    I'll try the clamp thing, thanks!
    Another silver B6
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    I'm gunna try that I have a shutter at 3k every gear once i hit full boost.
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    I had the same issue. I changed plugs and put 4 new Hitachi coil packs but it continued at WOT. A new fuel filter seemed to alleviate it for me however so it may be a fueling problem...
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Oct 29 2006
    Vancouver
    The guys at RPI suggested a new fuel filter too. I'll do that too, my oil change is almost coming up, perfect timing, thanks.
    Another silver B6
