Results 1 to 19 of 19
    Senior Member Two Rings vroompshert's Avatar
    Oct 14 2007
    Irvine, Orange County
    Question Low Oil light -top off with synthetic oil?
    Hello B7 owners,
    Basically at 11,400 miles I got a "low oil" light appear in the dash. I called Audi to see what the problem would be and they told me that if that light comes up, simply add a quart of oil to the car. I did a double check and according to the dipstick, I was at "MIN" on oil. They recommended Castrol Synthetic SAE 5-40, but at the time I didn't see any 5-40 so got some 5-30 castrol synthetic per instructions from the user manual.
    Anyone experience this problem often? I'm trying to figure out why I'm having to add oil on a new car? Any comments/feedback would be great.
    Many thanks,
    '08 Audi A4 2.0T Quattro MT6 / S-Line / Titanium / Navigation/ Convenience Package/ Bluetooth /19" Piano Black Rotiform MIA's w/ Hankook Ventus V12 Evo -235/35/R19/ H&R 10mm rear Spacer/ EVOMS V-Flow/ 6000k HID Fogs/ 6000k D1S
    Apr 12 2008
    2008 Audi A4
    San Diego, CA
    Re: Low Oil light -top off with synthetic oil?
    My car only has about 7700 miles on it, and i've had to add oil twice already, once at 2500 and then i did my first service at 5000, and then i had just had to add oil again... i don't know why my car is burning so much oil, but i was going to have it checked at the dealership...
    May 11 2008
    Naples,FL
    yea you can use 5w-30 or 5w-40 just make sure its full synthetic oil....I use mobil 1, doent really matter plus your getting your car serviced soon anyways....
    2.0 T Quattro - 20% tint,hardwired 9500i,alpine 757 amp,alpine 12" type r sub,RS4 Sway,Giac X-chip, VMR 19 710's wrapped in Conti Extreme DW, H&R Coilovers .
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    i dont think these cars should be burning this much oil. i would deff have a dealer look into it
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Oct 14 2007
    Yeah I remember the tech at audi mentioning adding oil was common, but I had no idea this would be required so early.
    I'm glad i'm not the only one with this problem...
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    you're fine... it happens... just stop rippin the car... but be sure to watch the oil levels... I would check it ever 2.5k miles... better yet just get oil changes every 5k
    Oct 14 2007
    haha I only rip it once in a while. But pushing the car to its limit will cause me to loose oil?
    Veteran Member Four Rings Doctor's Avatar
    Jun 02 2008
    A4 B7 20vt Quattro,Golf MKV GT
    Greece
    its something very common...Dont worry...Others burn a lot, others less, others not at all...Just check if you have any leak, such as from the pcv, or anywhere else, and if u dont, just be calm...it happens...
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by vroompshert View Post
    pushing the car during it's break-in will make the car consume a lot of oil(i'm sure it continues to break in for a long period even after your first 5k) I pushed my car hard to a lot after the 10k... it's common... i still consume oil and i'm at 35k just not as much as I did when I had less miles. I remember getting my low oil level light at 10k around...
    Registered Member Two Rings KOU's Avatar
    Jul 30 2008
    '08 Ibis: S-Line ext & SE pack
    I had the same problem a couple weeks ago (1,700 miles on the ODO - car is 2 months old) and called my dealership and they also said it was common and that I just needed to add a quart of oil. Went to Pep Boys and got some Castrol Full Synthetic (5W-30), solved the problem.
    They said the turbo, especially during the first few thousand miles burns a good amount of oil...I guess its normal???
    Nov 16 2006
    Skokie, IL
    Quote Originally Posted by KOU View Post
    THANKS for trusting us over your dealership lol... i usually played dumb... I would go into the dealership and be like I see this light on... I don't know why the oil is low... and they'd be like "oh no problem... it's common... we'll top it off for you"... squeeze every penny you can from the stealership dudes... stealerships will eventually rip you off somewhere else so why not? . I do the same with my windshield washer fluid... I tell them it's low and ask them to top it off for ya...
    however, so far my dealership have been honest and very courteous... yeah sometimes those guys don't know what they are talking about... but the lead technician usually know a lot more than those that sit behind the counter to "assist" you. And thank God for those TSBs... without those these guys would probably be lost.
    Jan 04 2008
    Cincinnati, Ohio
    I have 10K on my B7 and the oil light came on...went to the dealership to get some oil and they told me it was a common thing...nothing to worry about. They gave me 2 quarts of oil and charged them to the shop
    Mar 05 2007
    2012 BMW 135i M Sport, 2008 Jeep Liberty
    San Antonio, Tx
    My friend has an A3 and it happened to him. Car has low miles on it and the oil light just came on. We checked it and the dip stick said MIN. We went and bought about 2 quarts of 5w30 synthetic and he took it to Audi for an oil change. Car's fine.
    Papachristou: i just said "yeah well you are still driving a neon, and she still wants to ride in my car"
    Oct 31 2008
    2007 Audi A4 2.0T
    Schaumburg
    Hey people .. i have a 2007 a4 with 23500 miles. I have had this car since 1000 miles and now i am getting a "min oil" light in my dash board. I was wondering should i just add a quart of oil or should i get the oil changed and also considering the service is due in 1500 miles what would you suggest?
    Veteran Member Three Rings audidrver's Avatar
    Mar 31 2007
    CA
    Glad I don't have this problem yet. I babied her until 1k. Ripped on it everyday since. Fortunately I picked a winner because she likes to be pounded hard. I change her lube every 5k as others have suggested. I also stay out of boost until car is fully warmed up. Hopefully in the end all the extra precautions will balance out with all the fun we have.
    Established Member Two Rings cab7a4's Avatar
    Oct 09 2008
    Southern California
    adding more oil constanly is a definite downside to the a4.is is a common problem that will occure through the life of your car....mine does it about every couple thousand miles
    Veteran Member Four Rings viziers's Avatar
    Jan 27 2007
    2005.5 A4 2.0T, 07 A4 Sprint Blue
    NC
    My low oil light came on for the first time ever and ive got a little over 100,000 miles on the odometer.
    vizi
    05.5 B7 A4 longest running with no motor issues at 373whp
    Car:Custom JRP Mani & DP, GT3076, FWD to AWD conversion, IE 144/20, Wossner 83.5mm 9.2:1Cr, CM FX400, Ported Head Ferrea valves, EJ VC, EJ S3 Dv Flange, Custom STASIS Exh, Precision 600hp FMIC, RS4 injec, Tial 38mm, 034 SD mounts, Apikol Rear Diff, RS4 Sway, APR Snub Mnt, DO 4 port w/m direct inject, HPFPUpgrade 142bar PRV & StgII HPFP, 1.8 oil pump conv, Crnk dowel pin
    Absolute Automotive Tuned to 373+awhp @23.5psi (Corrected)
    Veteran Member Three Rings Elohite's Avatar
    Jan 14 2008
    San Antonio, TX
    I've had it a few times. 2 Qts at Dealership ~ $15 with tax so no biggie
    Garage Inc | APR | Britalman | 034| Stasis | Volk |Rotora | Deval | EuroGear | DTH | Thule | Forge | BSH | AWE | Evoms | H&R | Pioneer | JL Audio | TMA | ZiZa | KLight
    Nov 05 2007
    Naples, FL
    This just happened to me at around 9,600 miles. I just drove by the dealership asked them to top it off. And they did, no charge. They said whenever it happens, that I could just drive by and they'd do the same. The service advisor said that most A4's burn oil. As they get more miles on them, they burn less.
    2012 Monsoon Grey A4 2.0, Convenience Package, Style Package
    30% Front, 15% rear
