Results 1 to 19 of 19
Thread: need help
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    need help
    hey i havea thread up in the b5 s4 forum about my car shaking when i rev it up past 2-3k whuile parked... also shakes when driving if that info helps at all... it feels like the body is skaing not the engine
    anyway no check engine lights
    would vag-com help?
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
    Oct 31 2005
    Ashburn
    Re: need help
    My only guess would be really bad misfires, or some broken mounts somewhere. sorry i can't be of more help. besides the body cant shake without it being the motor, VAG it and find out.
    - Instagram: @Sinister_rs5-
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    Re: need help
    Sounds like you have a bad motor mount
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Veteran Member Four Rings Grishbok's Avatar
    Apr 15 2008
    Reston
    Re: need help
    check your spark plugs and make sure if your chipped, that they are gapped appropriately. I know on my car if you are chipped, your gapping needs to change from .32 to .28 and upgrade the plugs.
    2008 A4 Quattro Brilliant Black
    *SOLD*
    StreetTunedTV.com
    You are violating the 3 rules of forum posting.
    1. Title thread appropriately
    2. Use the search first
    3. If you didnt find what you were looking for, its because someone else didnt follow #1.
    Sep 02 2007
    2003 Audi RS6
    Re: need help
    i belive my motor mounts are fine... i just replaced my front snub mount that was bad and now my engine doesnt move nearly as much as it used to... if my mounts were bad wouldnt i be able to see the engine move?
    what would cause misfires?
    i wish i had vag... anyone close by willing to come by and vag my car? i work in a wine and beer warehouse so id be able to hookyou up with something i got at my house if not ill get you some lunch or something
    Apr 15 2008
    Reston
    Re: need help
    misfires can most commonly be cause by spark plugs being gapped too wide, especially in forced induction cars and chipped cars. To resolve that issue, get new spark plugs and gap them smaller. its .28 for my a4 2.0t
    *SOLD*
    StreetTunedTV.com
    Oct 31 2005
    Ashburn
    Re: need help
    How long has the car been doing this?
    Sep 02 2007
    2003 Audi RS6
    Re: need help
    it started all at once about 3 weeks ago but i havent driven it since just have been starting it in driveway... when it first happend i had a sulfur smell(guessing bad cats?) .. but since has gone away which isnt making sence
    so no one has vag com close by? would i hurt the car more by attempting to drive it about 3-4 miles to autozone
    Oct 31 2005
    Ashburn
    Re: need help
    Quote Originally Posted by NOVAS4 View Post
    I think you should be ok driving it, i'd help but my laptop it a piece of shit so i can't even VAG my own car. But i thinking back 2 years ago i believe my car was doing the same thing, turned out to be a clogged catalyic a bad front o2 sensor and bad egt all at the same time. Not sure if that would be your issue but i still think it's from misfires.
    Sep 02 2007
    2003 Audi RS6
    Re: need help
    i have a laptop id be able to do it on but dont own the cable or software...ohh well
    my friend has some kind of code checker for his mustang i completly forget what its cold... he thinks it would work ... anyone have any idea?
    May 28 2007
    Mt. Airy, MD
    Re: need help
    Hmmm, i'm not sure it would work, but idk. I'd stick with a vag-com
    Sep 02 2007
    2003 Audi RS6
    Re: need help
    ok well heres the deal... got it to autozone.. and had to convince the guy to check for codes because my check engine light wasnt on.... IT PASSED didnt find any codes
    so im guessing this rules out misfires
    could it be a clogged cat.?
    also the shaking has reduced alot maybe the snub mount just had to settle in place?(read that somewhere)... the car still just doesnt seem to run right .. maybe im jsut being paranoid..
    Veteran Member Three Rings swizzchard's Avatar
    Jul 28 2005
    05 B6 A4 1.8TQM USP
    Ellicott City, MD
    Re: need help
    coilpacks
    Sep 02 2007
    2003 Audi RS6
    Re: need help
    Quote Originally Posted by swizzchard View Post
    coilpacks
    ...explain please... i know bad coilpacks would cause misfires which would casue car not to run well/shake?... would bad coilpacks come up on a real vag-com? .. or is what they use at autozone equivilent to vag?.... sorry ... please educate me
    Jul 28 2005
    05 B6 A4 1.8TQM USP
    Ellicott City, MD
    Re: need help
    my first coilpack never threw a cel with the symptom for a while (over 200 miles)...then, the next time the symptoms happened, i never got cel but i just replaced all old ones.
    Oct 31 2005
    Ashburn
    Re: need help
    it depend on what autozone used to scan the car, VAG can also read soft codes/ codes that don't emit a CEL. So there might be something a VAG-Com might detect. Do you have a boost gauge, what is your idle hg at?
    does the car go into boost, how much ? what happens?
    Sep 02 2007
    2003 Audi RS6
    Re: need help
    gotcha... umm 16-21 hg idle .. its in stock mode so boost spikes to 10-11.. tappers to 8ish... when it doesnt feel normal is at idle/when im just starting to go... i did a 45-80mph pull and it felt fine... but my idle seems to be rough but rpm stay just about same...
    Sep 02 2007
    2003 Audi RS6
    Re: need help
    well just thought id throw in another update for informational purposes ...
    anyway vernon (highPSI-s4) came over today to vag the car after symptoms of shaking and noises got much much worse... had tons of misfires in cyl 4 and plently in a couple others... so we switched out ICM and misfires almost went awaay... just have some here and there and hope new coilpacks and sparkplugs will get rid of them
    thanks again vern
    Oct 31 2005
    Ashburn
    Re: need help
    anytime
