Results 1 to 10 of 10
    Oct 05 2008
    SP
    '02 B6 A4 1.8TQ, any weakness that needs repair/replacement?
    Hi
    With about 60,000 miles on it, please advice should I pull the trigger to buy it? Anything to watch out for in the future for potential major repairs/replacments? My first turbo quattro, so quite worried about these 2 major components especially.
    Thanks
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Re: '02 B6 A4 1.8TQ, any weakness that needs repair/replacement?
    quattro is solid. turbo at 60k should not be an issue, so long as the car has been properly maintained.
    i would as about records of work done on the car. oil changes etc.
    timing belt should be considered pretty soon if it has not already been replaced. the water pump is a known weakness and can cause timing belt failure.
    other than that, 02 sport is the supposed lowest of factory suspension, has heated rear seats and perforated (air) leatherette seating surfaces. a nice ride.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    Oct 05 2008
    SP
    Thanks for the reply. just found out that the ride had quite a no. of modifications done, off the top my head that I could remembered are:
    1. MTM Stage 3 with K04
    2. 18" rims
    3. MTM clutch
    4. Stoptech front BBK
    5. K&N air filter
    6. Broquet
    7. sway bars
    8. ICE
    etc
    The list goes on. I'm a sticker for minimal mods when I buy a used car, so quite a bit worried when I heard about the mods. Or should I not be worried?
    He also mentioned that the fuel consumption wasn't much affected at 9km/L for city driving....was wondering after all these mods it's still not good? Any comments?
    Registered Member Three Rings ILikeBigBrakes's Avatar
    Sep 27 2008
    2002 Audi A4 1.8 Q&A
    Orlando, FL
    I was a little worried too since I just bought mine with mods, some I still am trying to get the info on what they are. But the car runs so solid and after reading on here how well they are just keeping maintained you should be fine. Looks like some good mods to start also, enjoy the car i know i am!
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by kinetic View Post
    2. 18" rims
    3. MTM clutch
    5. K&N air filter
    6. Broquet
    7. sway bars
    8. ICE
    etc
    Oh yeah man you should be totally worried. Since I'm such a compassionate and caring person, I'll swap you my k03/brakes/17" wheels/sway bars, for your icky k04/BBK/18's/and upgraded sway bars.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Sep 07 2007
    San Francisco, CA
    Quote Originally Posted by nihil View Post
    Lol. To the OP, it sounds like the car is actually quite tastefully modded, so I would assume that it has been well maintained as well. I say go for it
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    before u buy, just check the usual..oil, if u can compression test it, make sure its hitting correct boost and runs smooth, something i did not do when i bought mine, was check the damn coolant resevoir, make sure it dosnt look like coffee like mine did.. sounds like a pretty stable car from the mods, sounds like who ever did them knew what they were doin
    good luck
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    May 22 2007
    oakland ca
    that is not my dept, but I am sure you'd hear folks with arguments for or against this being a bonus.
    2. 18" rims
    18 is average/conservative on most peoples standards. i personally would not go larger, but that is just me. 18 is a nice balance of looks and performance, but does give up some ride quality over 17's.
    3. MTM clutch
    I'd love a new performance clutch.
    great brakes. not oem, but you could easily sell them (for cheap to me please!)
    5. K&N air filter
    only concern is if it is over-oiled when cleaned. otherwise it's great
    6. Broquet
    i actually do not even know what this is.
    7. sway bars
    dramatically improves the handling of the car. I personally do not notice any change in ride quality on normal driving, just better in the turns.
    8. ICE
    if you have an ipod, why wouldn't you want this?
    etc
    depending on the price this car has a lot of the work done to it that most folks on here do anyway. you will not hear too many folks saying bad stuff about them (unless they are trying to buy the car out from under you....
    good luck.
    post up some pics!
    Veteran Member Four Rings flyinb501's Avatar
    Apr 18 2005
    '02 Audi A4 1.8TQ MT5, 2000 CB
    Minneapolis, MN
    2. 18" rims
    3. MTM clutch
    5. K&N air filter
    6. Broquet
    7. sway bars
    8. ICE
    etc
    I'll tell you what man, if you want to save yourself some dough and have a car that is actually fun to drive, this is the way to go. I bought my car with all the go mods already installed (full revo k04, and all supporting mods). The car had 55k miles on it. It now has almost 90k miles and the only problem I've had is a coolant leak. It has been a great car for me. Also, I'm getting 25-27 mpg. Just wish it was faster...
    '02 A4 1.8TQ MT5: Revo tuned k04/ Eurocode FMIC, testpipe/ Neuspeed exhaust, snub, SS/ Forge DVR/ 19" Sevas/ S4 blades/ Painted Lowers/ VDO boost gauge/ Tein springs/ Lip spoiler/ Blackout grilles/ Icelink/ Alacantara shift boot
    Oct 05 2008
    SP
    Thanks everyone for the reassurances, and the gentle replies to a noob. I'm gonna throw in another scenario which complicates matter a bit and replies maynot be gentle anymore, being in a Audi forum. But I'd to as I almost pulled the trigger on this ride after reading all the nice replies........now someone is trying to sell a great priced '04 MkV Gti DSG to me. Arggg....decision decision.
    Any comments on the B6 A4 1.8TQM vs MV Gti DSG. It's probably not a fair comparison but hopefully someone had driven both can make a comparison, esp on the drive itself.
    Thanks again
