I recently bought an RS4 (previous car was an E46 M3). In my M3, I hardwired the Valentine 1 by tapping into the power feed for the homelink which was located in the map light cluster in the roof. There was also a ground in the same cluster area. With that in mind, I have a couple of questions:
1. Has anyone hardwired the V1 in an RS4 using wiring and a ground in the map light cluster in the roof? This is my preferred method as it worked flawlessly in my M3 for years and didn't require any "home runs" to the fuse box or tapping into fuses.
2. As an alternative, I tried hardwiring the V1 using the DIY on this website that uses power from the fuse box and a ground near the fuse box (I think ELEVENS posted it). Unfortunately, the fuse tap that I bought from Radio Shack doesn't stay put. For those of you that used a fuse tap, what kind did you use? For those of you that wrapped a wire around the fuse prong, how exactly did you do this (a pic or description would be great)?
Thanks.
