Results 1 to 24 of 24
    Veteran Member Four Rings HTA A4's Avatar
    Jul 11 2008
    2002 1.9L HTA3076R A4
    Illinois
    Gremlins in the f'ing turbo
    Ok, so when I get to about 5500rpm the turbo backs off of boost (from ~20 to 10 or 11) for only a split second. Then it goes back to full boost.
    Any ideas?
    Thanks guys
    Anthony
    Eurocode Tuning | fifteen52 | Speed Freaks Fabrication
    BetaAlphaTau Member #41
    Jul 11 2008
    Illinois
    Re: Gremlins in the f'ing turbo
    Good morning bump
    Anthony
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    well good morning to you to sir
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Time to do vagcom logs, could be the car closing the throttle.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Throttle plate is most likely closing...try turning off the ESP and see if the Gremlins go away.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Weren't you going to look at your WG to figure out your late boost problem? I can not keep track anymore.
    -Doug
    Jul 11 2008
    Illinois
    ^Yeah, it was checked. Everything is working well there..
    Anthony
    Jul 11 2008
    Illinois
    I'll log it tonight and post it.
    Anthony
    Jul 11 2008
    Illinois
    Quote Originally Posted by 400HPA4 View Post
    Thanks Greg. I'll give it a shot
    Anthony
    Jul 11 2008
    Illinois
    Ok so it's more like 6500 but look at 6500rpm in the actual boost.
    Anthony
    Jul 07 2004
    socal
    I think your URL for your picture is messed up, you put http://i45.photobucket.com/albums/f90/gtrsa4/log-1.jpg
    Jul 11 2008
    Illinois
    It's not showing up? It should be an image
    Anthony
    Jun 14 2005
    Anaheim, CA
    pic looks fine to me... looks like wastegate is opening up suddenly and staying open? what kind of wastegate do you have?
    Brandon @ VMR Wheels
    Jul 11 2008
    Illinois
    It's not externally wastgated...
    Anthony
    Jul 11 2008
    Illinois
    I'm going to have my friend, an Audi ASE certified machanic, look at the wastegate to make sure everything is good there.
    Anthony
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by GTRS A4 View Post
    Please do. I think it will solve both you and 7Speed's problems.
    -Doug
    Jul 11 2008
    Illinois
    lol All right, thanks a lot Doug. I really appreciate your help through all of my problems!
    Anthony
    Feb 17 2005
    Sarasota, FL
    Get rid of the POS N75 too and put the MBC you have in its place
    Jul 11 2008
    Illinois
    Quote Originally Posted by A4ringedONE8T View Post
    Will do. Something I could do myself right? I don't really know where to mount it or even how to install in...
    Anthony
    Dec 03 2005
    2 pedals 1FG
    connecticut
    You can get by with the N75. I actually prefer it over the EBC for my set-up. Probably sell my EBC once I get my car back. Complete w/ the ash tray its molded into.
    -Doug
    Feb 17 2005
    Sarasota, FL
    Just as the N75 is, the signal line coming from the compressor in the bottom of the MBC and the line to the wastegate to the side connection on the MBC. It removes one more electrical, ECU controlled part from the mix. Do it, even if its only to troubleshoot. N75 isnt ever going to make shit for power or spool I dont care what the BT setup is or who is running it. Doug seems to think his setup is god though, so he may be the only one to do so
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Nope. I just dislike a lot of the decisions you have made in your set-up. Its robbing you of major amounts of power. That is the only reason why I give you a hard time (at times).
    -Doug
    Feb 17 2005
    Sarasota, FL
    I will hopefully have #'s this week, perhaps you will have something to compare?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    not sure yet. i have to make a phone call tomorrow to see how things are going.
    -Doug
