Thread: Oil consumption
    Senior Member Two Rings EssPhore's Avatar
    Jun 01 2008
    2005 B6 S4, 2007 KTM EXC 450
    So Cal./I.E.
    Oil consumption
    I'm just curious to know what everybody elses S4 oil consumption is like. How often are you adding, and how much? I've searched, and didn't see anything specific to this. Thanks in advance.
    Sean
    Jun 01 2008
    So Cal./I.E.
    Re: Oil consumption
    Nevermind...I found my answer. I'm glad I found it before the "use the search" nazis came on board!
    Dec 05 2006
    So. Cal.
    Re: Oil consumption
    Jun 01 2008
    So Cal./I.E.
    Re: Oil consumption
    Hey RAudi.......I see that you are located in SoCal. Would you happen to know where I can buy the "Higher" grade oils? I currently use mobil 1. I live in Corona, but work in Anaheim Hills. I know Pure MS in Temecula sells a oil changing "kit". Is this my only option, or do you know of any suppliers in either of my areas? As for anybody else, please feel free to chime in. TIA.
    Sean
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Re: Oil consumption
    Super Autobacs in OC and West Covina have some high grade oils. I generally order from Pure MS anyway, you could probably place the order then drive to pick up.
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
