Results 1 to 10 of 10
Thread: wheel bearing
    Senior Member Two Rings ahaters46's Avatar
    Sep 03 2008
    99.5 1.8tqms
    dover new hampshire
    wheel bearing
    rear passengerside wheel bearing is completly shot i wanted to run it till i saved up money to get it fixed but its not gonna happen. whats the cheepest /easiest way to get it done if i end up doing it do i need a press i have no idea
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    Re: wheel bearing
    Yes, the old bearing will need to be pressed out of the hub and the new one pressed in. Once you get the hub off, you can take it to a auto machine shop or garage and have the press work done. Generally in the $25 range.
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: wheel bearing
    I just ordered a pair from pureMs @ 58 each. If you do the work yourself its just like manufan mentioned, 25-50 bucks to get them pressed into the hub. Got to take the entire rear upright off.
    -18 718 GTS
    Sep 03 2008
    99.5 1.8tqms
    dover new hampshire
    Re: wheel bearing
    alright thanks guys
    where did you order your parts i saw a few on ebay but i dont no
    Nov 16 2007
    northern pa
    Re: wheel bearing
    I like this place germanautoparts. They sell quality parts and ship super quick with honest shipping prices.
    Dec 14 2006
    Halifax, NS, Canada
    Re: wheel bearing
    If one failed I suggest doing the other side at the same time. Mine failed within a few months of each other.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Nov 16 2007
    northern pa
    Re: wheel bearing
    Oh, one point if you're taking it apart yourself. If the ABS sensor doesn't come right out, don't start twisting and pulling on it or you'l be buying that too. It plugs in under the back seat, you can unplug it and leave it in the housing. Good point from Squarrl, do them both while you're doing the noisy one.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Re: wheel bearing
    pepboys charges $30 to press it in for you. I remember total for mine were like $90ish doing the labor myself and getting the parts from ECS.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Sep 03 2008
    99.5 1.8tqms
    dover new hampshire
    Re: wheel bearing
    ya weds my next day off so im gonna make some things happen ill look out for that abs sensor too man. i dont think theres a pepboys anywhere around here so im just gonna hit up a local shop ive gone to before
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: wheel bearing
    I also recommend www.GermanAutoParts.com - I order from them often. They have very quick and very fair shipping. I also ordered a wheel bearing from them, I think they had a price mistake when I ordered it because it was a quality brand for much cheaper than anywhere else. I installed it myself, paid $30 to have it pressed in. Very easy replacement if you like to work with your hands.
