Results 1 to 6 of 6
Thread: k04 problem
    Apr 26 2007
    Detroit
    k04 problem
    ok i got used k04 from one of the members on this forum and the downpipe/catalytic converter side was a cruck so my question in can i put downpipe from k03 on k04? thanx
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    Re: k04 problem
    yes..uses same downpipe
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: k04 problem
    confirmed. k03 and k04 are basiclly the same turbo just diffrent exhaust turbine size.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Re: k04 problem
    what do you mean "a crunk"?
    there are different model K04's you need a K04-015. the others will not fit. I hope you got the right one or you just got yourself a nice paperweight.
    Jul 06 2008
    red rock or new braunfels
    Talking Re: k04 problem
    with enough cutting and welding you can get a 1471 blower to fit
    Dec 18 2007
    nj
    Re: k04 problem
    maybe it is a K04-015, but i don't know what the hell a "crunk" turbo is so i'm assuming it's got the wrong flanges on it and it won't fit and that is what the OP means.
    if the guy really did jump into this by getting a K04-001 or a K04-020 the chances are that he will have the knowledge to be able to fabricate everything up to work are about one in a million. telling him he can get it to fit is just bad advice. he is best off to sell it and get a K04-015, or better yet not to waste his time and money with a K04.
    again, this is just going by my assumption that he has the wrong turbo and he may not.
