I just built the boost leak tester as described by Martini on a4mods.com. I have a small pancake tank air compressor - the kind usually used for inflating tires and stuff. In Martini's instructions, he talks about charging the system to 10-12 psi. I can't really do that with my tank - it's either on or off. If I couple it onto the tester and then turn it on until it gets to 10-12 psi, then I should be ok, right? Don't professional compressors let you send the air out all at once, whereas mine will be "filling" the engine's vac/boost system as it compresses air?
