Results 1 to 6 of 6
    May 21 2007
    Florida
    limp shifter? no reverse, wtf??
    so im driving today with a guy from my club, we go to a audi/vw bbq and then go to pick up our website guy. as we are pulling into the parking lot of the place we are meeting him, i shift out of gear and my whole shifter just goes limp. it has no resitance at all. flopin around like a dong. when i try to shift into reverse, it goes into first. i can go forward though. i left it at that resturaunt overnight and am having it towed tomorrow morning to the shop i had my clutch done at a few weeks ago. im just curious as to what the hell could cause this?? it seems so damn odd that it would randomly just start being floppy like this. i didnt want to drive it incase it was a loose bolt and it fell out while driving and i couldnt get in or out of any gear.
    2018 Navarro Blue Q5
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: limp shifter? no reverse, wtf??
    same thing happened to my '86 Chevette. Think it was a bolt. I could lift up the shifter and poke it around.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    i'm sure it's the selector arm, it willl just need a bolt.
    May 21 2007
    Florida
    which one is the selector arm? in with the shifter or under the car? im going to check it out before i get it towed tomorrow.
    Aug 16 2004
    SE PA
    Quote Originally Posted by doublezero30 View Post
    under the car, but it runs from the front of the shifter to the tranny. my guess is the shop unbolted it from the tranny to do the clutch.
    May 21 2007
    Florida
    damn i was afraid of that. im unsure if ill beable to get under my car where it is. ill try to get up there early and bring my jack.
