Results 1 to 21 of 21
Thread: Going low
    Veteran Member Three Rings UBERS4's Avatar
    Sep 18 2006
    2005 Arctic White S4
    Earth
    Going low
    I wanted to post here in the A4 section as more people seem to run low/aggressive suspension setups on their A4's rather than the S4 guys. I am running Tein SS coils with a 24 1/4 inch fender to ground measurement. After removing the 12 o'clock bolt in the front front, my rubbing has seized in the front. However, I am still getting some rubbing in the rear, either over big bumps at speed or with multiple people in the car.
    I really don't want to have to raise the ride height but I want to avoid rubbing at all costs. I basically want to see what people do who are as low as me or even lower. From what I can see and hear, I am only rubbing the carpet and not the fender. Nothing this, is it worth even worrying about?
    My last question is what would be the problem with running more negative camber to correct this? I obviously know it impacts tire life but realistically, how much? I have another alignment set up for Tuesday so I'd really like to get everything dialed it.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    |Dunlop Tires|DPE Wheels|Oettinger|Rotora|Tein|GIAC|Supreme Power|
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Going low
    rubbing at 24 1/4inch ground to fender?! im at 21" with no rub gotta love B5's
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    Re: Going low
    your probably just rubbing on the liner. try to cut or remove the liner and see if you still rub.. either way, it will fix it self if you do nothing (ie wearing down or ripping off) in anycase, theres nothing to worry about. applying negative camber will help, but it will still be rubbing on the carpet. i had the same issue with a 24.5" drop and running 18x9.5 et 35 running 245 tires (little stretch)
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Going low
    contact Captain, he knows whats up
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Sep 18 2006
    Earth
    Re: Going low
    Quote Originally Posted by B6driver View Post
    Great advice, thanks!
    I'm going to shoot a PM to Captain as well. Thanks guys. Any more thoughts would be appreciated.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Re: Going low
    What tires are you running in the rear (brand and size) and what size and offset are the wheels?
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Three Rings jojoampt's Avatar
    Jan 19 2008
    02' A4 Avant, 1.8T QM, 08' S-Line A3 MT
    Humboldt County
    Re: Going low
    so how do you remove the bolt under the front fender? im at 25 in front and i rub when i go over a bump. do you just dremel it off? whats it even there for?
    Jun 13 2005
    Audi
    Re: Going low
    Quote Originally Posted by jojoampt View Post
    You could dremel it off... I would recommend just unscrewing it
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Veteran Member Three Rings ThatGuyAlex's Avatar
    Jan 24 2008
    NorCal BayArea
    Re: Going low
    It holds your fender liner on. But u can just use a zip tie if you want. How are you rubbing at 25" tho. Whats the offset on your wheel?
    Fastest slow car down mountain roads you ever saw!
    Jan 19 2008
    Humboldt County
    Re: Going low
    35, i was wondering the same thing, i dont rub unless i go over a big bump or dip, i think the tires i got are a bit beefier than most even though they are 235/35/19 they seem beefier... they are BF Goodrich G-force 2's... oh and i dont even have a fender liner in front...
    Sep 18 2006
    Earth
    Re: Going low
    Quote Originally Posted by actlsub9 View Post
    Running 235/35/19 Dunlop Sport Maxx tires. Wheels are 19x8 inch DPE's w/ custom offsets. I don't have the exact number but will get it.
    I never had a problem until I got the car this low. It seems that extra 1/2 inch made all the difference in the world but I'm determined to get it right. I'm awaiting a PM from Captain so maybe he can chime in.
    And the 12 o'clock screw is an easy fix, unscrew and bend the tab in. Like noted, it's designed to hold the felt in but without it, it won't matter. It will take care of your rubbing in the front guaranteed. I really don't know how you rub at 25 inches. Unless your tires are just that much beefier.
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Jun 13 2005
    Audi
    Re: Going low
    Quote Originally Posted by UBERS4 View Post
    I also have the Dunlop SP Sport Maxx except in a 225/35/19 and my wheels are 19x8.5 et32 and I am at 24" even all around without rubbing problems. Maybe your DPE's have a lower offset?
    You can see how close it is here though...
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Sep 14 2006
    Eagle Rock, LA, Ca
    Re: Going low
    heres my setup 18x9.5 et 35 with 245 tires
    Jan 10 2007
    VA
    Re: Going low
    trim the rear fender liner.
    Feb 17 2005
    Sarasota, FL
    Re: Going low
    I would recommend not going past -2 degrees in the back, the inside of the tires will wear horribly. My last alignment I had the back set at -2.5 to help the same problem with 9.5's (245/35) in the back. It did help, still rubbed on big bumps or with anyone in the back but never damaged the fender or paint, only the carpet wheel well liner
    Heres a few clearance pics of my car, height is 24.5" rear , 24.25 front
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: Going low
    If you're just rubbing on fender carpet, it's nothing to really worry about. You have two choices to fix it: trim the part off that's rubbing, or just let it keep rubbing and it will eventually get worn off by the tire and stop.
    If you're rubbing on the fender, you'll want to camber in the wheels a little bit. By the sounds of it, you're just barely rubbing, so you won't need a lot. I have a DIY for camber adjustment here.
    As for tire life, I run close to 4 degrees of camber in the rear on my car and I get pretty decent tire life. It's not really the camber that kills your tires as much as the toe-in that often comes with the camber. If you have the car aligned with minimal toe-in you should have pretty normal tire wear.
    -Darrick
    Sep 18 2006
    Earth
    Re: Going low
    Alright guys, I'm still rubbing slightly and it's getting really annoying. Now, I seem to be rubbing in the front a little even though I removed the 12 o'clock bolt. There's some slight marks on the inside of the fender that gives it away.
    My wheel offset - et30. What's the best way to combat all of this? Run more camber front and rear?
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Nov 14 2006
    Gig Harbor, WA
    Re: Going low
    Switch your tires to 225/35's.
    -Darrick
    Sep 18 2006
    Earth
    Re: Going low
    Quote Originally Posted by Capt. Obvious View Post
    I wish I could. I just got these tires from Dunlop and they're brand new. It would be sin to dump them.
    I'm going to look in to rolling/pulling the fenders. I got some other work that will be happening on my car over the next few months so this would be a good time to get the fenders done.
    This might be a noob type question but if I'm only rubbing slightly and not too often on the fenders, is it that big of a worry?
    '05 Audi S4
    |Europrojektz|
    Midwest Director
    Sponsored by-
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Re: Going low
    Just get them rolled then
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Oct 06 2004
    Minnesota
    Re: Going low
    Not at all. Start worrying when you are cording the sidewall from rubbing.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
