Results 1 to 14 of 14
    Aug 09 2007
    Mount Airy, MD
    Arrow Boosted Tech Intercooler pipes?
    Hey guys,
    I know it says these are for the b6, but does anyone have any experience with them? and could they be used on a b5?
    About half down on this page.
    http://www.boostedtech.com/products.asp
    for the price, i might just try it.
    - Will
    06_Avant . DTM K0R-Gt. etc...
    The Avants Timeline
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Boosted Tech Intercooler pipes?
    Might work, but using that much hose is never a good idea.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Looks a lot like the silicone piping available from 034.
    Jim
    I Do Werk.
    Jul 07 2004
    socal
    034 set is short.
    Where does the BPV go?
    Aug 09 2007
    Mount Airy, MD
    yeah, except its a heck of a lot cheaper. if i went this route i would probably trim the pipes down some as well as get a section of aluminum pipe made up for the dv and map sensor (relocate the dv to the cold side). i might make this my fall project
    - Will
    The Avants Timeline
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    can you buy the 034 set seperate?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 05 2007
    Yeah, but they are like $250 bucks. Link
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    for 59 i might just try them too... let me know how they pan out man
    Nov 15 2007
    Audi A4
    Redding, California
    they are only 2" tho...isn't that guna be restictive on just about any setup besides stock?
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by B518T View Post
    No way, im sure 2" is good enough from k03-k04 or even my T28.
    My 5-Speed Swap DIY
    - B6 USP
    Aug 09 2007
    Mount Airy, MD
    yeah and right now im only rocking a k03, with a k04 max in the future
    - Will
    The Avants Timeline
    Mar 09 2004
    nw michigan.
    Why even bother with anything for a k03 or k04? I've had the full Samco set on my car for years and doubt it gains anything whatsoever over stock. Complete waste of money unless you can prove the stock parts are causing real problems.
    Jim
    I Do Werk.
    Aug 09 2007
    Mount Airy, MD
    well ive got the just-intercoolers front mount, and im always blowing off my pipes. i like the samco set, but i would only use about half the pieces i think. that and the samco set would need some tweaking to put the dv on the cold side.
    - Will
    The Avants Timeline
    Jul 07 2004
    socal
    Quote Originally Posted by onemoremile View Post
    That hose kit doesn't, but the set he posted replaces the restictive S hose at the throttle body.
