Results 1 to 20 of 20
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    Upper control arms pinch bolt.....
    I know there are write ups on how to remove this when doing the control arms and cv boot and I think I've looked at every one of them......but anyone have any other suggestions? If I try twisting it any more I feel like it's going to twist the head off and I really don't want to have to drill it out. I've lubed it up pretty good, but still nothing.....any help is appreciated.
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Upper control arms pinch bolt.....
    Quote Originally Posted by SLC_S4 View Post
    If it feels like it's going to twist off, it probably is. I twisted off the head of mine and then had to use heat from a torch and a punch. Make sure the suspension is jacked up to take the load off the arms. What are you doing, control arms? suspension install?
    08 S4- Stock SOLD
    Jul 15 2007
    2001.5 S4
    Utah
    I'm doing axles....
    Do I need to jack up both sides, or just the side I'm working on?
    -Seth
    Jan 29 2007
    08 S4 00 S4
    MD
    One side at a time should be fine. You've got the sway bar off, right?
    08 S4- Stock SOLD
    Jul 15 2007
    2001.5 S4
    Utah
    No, nothing I've looked at has mentioned that the sway bar needs to be removed. Would that help?
    -Seth
    Jan 29 2007
    08 S4 00 S4
    MD
    Never done axles, so I don't know if the sway bar needs to come off, it couldn't hurt. However, when I bought my car, I had to have a driver side axle replaced to pass MD inspection and I KNOW they didn't pull that pinch bolt. You sure there isn't a write up somewhere, maybe on audiworld for replacing the axle without removing the pinch bolt? I'm thinking it can be done...
    08 S4- Stock SOLD
    Jul 15 2007
    2001.5 S4
    Utah
    I did find one for a 2.8 A4 that just moved the inner joint into the empty space above and in front of it and then pulled the outer joint.....but there isn't quite as much room in the 2.7. I've tried and can't quite get the outer joint moved far enough to pull it all the way out.
    -Seth
    Jul 15 2007
    2001.5 S4
    Utah
    And before I try anymore, is that bolt reverse threaded? I'm thinking not, but I thought I'd just ask.....
    -Seth
    Jan 29 2007
    08 S4 00 S4
    MD
    No, it's not reverse threaded. Search on audiworld. 30sec worth of searching and I found 2 posts about just jacking up the hub as fas as you can and working out the axle from side to side. Not very detailed, but you should be able to find better ones, maybe with pictures. Good luck.
    08 S4- Stock SOLD
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    You shuold be fine with just removing the upper control arms to get the axle out. Since you already beat on it might as well finish it. Use a torch to heat it up and hamer it, it should come out. I have dome many axels in almost every audi and torch works the best just watch out so you don't burn the control arm boots, once it's hot air hammer or just regular hammer and it will come out. Once it's in use a punch to punch it through.
    P.S If you go to Advance Auto they have bolts that are exacly like audi pinch bolts and are like $1 a peace. Take your old one in and tell them you need one just like that.
    i soaked my for 4 days before w/ pb blaster, if you have less time torch and hammer works well.just put some anti seize when putting it back
    md
    you do NOT need to remove the pinch bolt or the upper c/a's to get the axles out.. , place the car on jack stands, remove the axle bolt, then remove the inner axles bolts, place a floor jack underneath the rotor with a rag or piece of wood and compress the suspension, wiggle the axle out and replace the axle.. I did both ft axles in 1.5 hrs.. not a hard job at all.. just make sure that you have a friend that can help you turn the axles while your underneath the car for the inner bolts. ( makes it alot easier).. you do not need to remove any other suspension pieces to do this job
    Jul 15 2007
    2001.5 S4
    Utah
    Quote Originally Posted by md s4 View Post
    Thanks, that's what I just did and it works great. Got the axle out just with my brother turning the axles, didn't have to compress the suspension or anything.
    -Seth
    Senior Member Three Rings jblinga's Avatar
    Jul 24 2008
    '01.5 S4, '96 Maxima
    Mor_onville U.S.A.
    See what happens when you don't ask mr. bling for help...You have to make posts to figure it out!
    haha jk glad you got her done!
    '01.5 S4 6MT 2+
    '96 Maxima (DD)
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    i have no idea how you got the axle out without compressing the suspension, or turning the wheel to full lock ... because this is how ive done 5 axle jobs and there is a method to doing it as clearances are very tight
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    i always removed the upper control arms. you can then pull the axle from the hub and do the boot replacement while the axle is still mounted (if only the outer) I did mine 1 hr each side.
    it is easier if you raise the whole front up so it take the tension off the sway.
    as for the bolt, soak that thing in pb blaster or heat it with a torch.
    Jul 15 2007
    2001.5 S4
    Utah
    Quote Originally Posted by jblinga View Post
    Haha I know, I was regretting it the whole time
    -Seth
    May 06 2004
    W124s
    PA
    Another way....
    Remove the rear lower curved arm nut securing to the wheel bearing housing. Knock it out and pull out of the wheel bearing housing. Turn the wheel to full lock, pull the outer joint out. Hammer the joint off the shaft.......
    Keep right pass left, it's the law!!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    torchhh
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Jul 15 2007
    2001.5 S4
    Utah
    Quote Originally Posted by DxC View Post
    Just a little bit of maneuvering got the axle out. I did have to have the wheel to full lock. I had to compress the suspension to get the new axle in though.
    -Seth
