All logs are WOT 3rd-gear; I couldn't get 4th gear because I couldn't get a stretch where I could pull and log at the same time without killing myself.
I did try for one log from dead stop through redline 4th gear. But I managed to be an idiot and never actually hit "start" on the logs. And it was scary because I ate up road way fast and according to my GPS actual speed, I was at 127mph at 6600RPm in 4th gear. With a bend in the road coming up, that was nuts. Brakes work good, nonetheless.
First, here are the unitronics settings... the fuel trims are nothing but what Unitronics suggested on Vortex. The timing is +5.25 as you can see.
Here is BTDC, CF, and block 032 Lambda. What is up with negative Lambda, and what does that mean?
Here is BTDC, CF, and block 31 Lambda:
Here is Req vs. Actual boost, IAT, and EGT. Note on this a few things. First, I still have a small boost leak. I reached requested boost at 3760RPM but it didn't hold well due to leak. On the IAT the FMIC seems to be doing what it was supposed to as IAT dropped after shift out of second. Ambient was 67 degrees farenheit I think; EDIT: that's 19.4 celsius.. And finally, on both the IAT and EGT, this log was running HOT because I was running the piss out of the car.
On all, I didn't wind out second prior. I had to try to shift, see the road, and hit start on the log. All where almost boggy on 3rd gear WOT and not coming out of a high moving speed from second.
Being that I'm not sure what all I'm looking for but have a general idea, lay it on me. I'm not too worried about destroying anything at this point because I'm just a week or two shy of storage on the car, and this winter will be 2.0 stroker and built bottom. So right now I'm just playing and not worried of the consequences.
