Results 1 to 9 of 9
Thread: wheel spacers
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Question wheel spacers
    Best price on a 10mm spacer kit? where to get it.......
    do i need to buy longer bolts, or is that only with BIG spacers? if i do need the bolts what length??
    sorry for so many questions, i've never dealt with spacers before. And my tires are rubbing on my control arms a little bit. need help. hopefully someone that has went through this already will chime in.............
    TIA
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: wheel spacers
    10mm is big, yes you need longer bolts. Look on purems.com or ecstuning.com they both have good deals most of the time.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: wheel spacers
    btw what part of FL are you from?
    Sep 01 2005
    Re: wheel spacers
    Quote Originally Posted by t1demont1 View Post
    i'm from Davenport, RIGHT outside of orlando. my problem is that my inside tire sidewall is scraping against my control arm. you think i should go with a smaller spacer, I'm pretty sure it hardly rubs., but rubs enough to eff up my front tires.
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Re: wheel spacers
    5mm should be fine, you dont want too much more, it ooks like your sitting pretty low, gonna have to watch out for fender rub.
    You want to keep the same amount of thread as it came from the factory. example: 5 mm spacer equals 5mm longer bolt etc...
    Apr 25 2007
    millersville, maryland
    Re: wheel spacers
    Yeah if the car is moving and the wheel goes on a 5mm spacer should get rid of the inner clearance issue without pushing it out too far to worry about fender rub
    Account Terminated Three Rings pzp107's Avatar
    Dec 02 2007
    State College pa
    Re: wheel spacers
    I have a set of 4 hubcentric spacers, new, no bolts though, in 10 mm. Can get bolts at lots of places. PM me if interested.
    Account Terminated Two Rings MK3_WAGEN's Avatar
    Sep 27 2005
    DFW
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    Re: wheel spacers
    I just put 10's on mine. I ordered my bolts from Black Forest Industries, for 1.85 a piece. I think I got 1.5" ones.
    free earl
