Results 1 to 6 of 6
    Veteran Member Three Rings 2BblkAudis's Avatar
    Feb 15 2007
    San Mateo, CA
    GIAC ecu installed
    I just got a GIAC flashed M-box and installed it in the car. The ecu has stock, pump and race. The pump program is the 93 octane program, so i filled the tank with a mix of 91 octane and 100 octane to get an approximate 94 octane mixture. After filling up, I switched to the pump program and drove conservatively for about 30 miles. After that I started to give it some more gas and started boosting a little more. The question I have is that the car spikes at 22 psi and easily pushes 20 psi. The problem I'm having is that intermittently the car will sputter for a little bit then start boosting again. Its almost as if the car is not getting fueling or something. Anyone have any idea what's going on?
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: GIAC ecu installed
    Quote Originally Posted by kinamro View Post
    Stage 1 chip should not be spiking or coming anywhere near 22 psi. Somethings up.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    Damn I am sorry that is happening. Hopefully someone is on here that can shed some light on this. I never had that problem when I had the ecu. Please let me know if I can do anything.
    Train Hard, Go Hard, But always be Humble.
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Mine is spiking high as well, to like 21 then tapers off to 18. I have APR, and it should be 19 taper to 17. The reason my boost is going so high is because my N75 is dead (figured that out today). Yours is probably on its way out as well.
    Feb 15 2007
    San Mateo, CA
    Thanks for the update guys. I'll look into getting a new N75. Hopefully that will cure this issue.
    Jul 26 2008
    Jersey
    Log it before you go and get a new one.
