When I installed my turbo timer I had to rewire the central locking system and splice into one of the wires that goes to the computer diag plug. Mine has been working fine ever since I installed it.
To reprogram your remote you have to have the key in the ignition and in the acc position. Then lock the car using the drivers door, hit your unlock button on your remote and the cars parking lights will flash once (if you are programming a second remote hit it twice to program a second key up to 4, I think, and the lights will flash 2-4 times depending on how many times you press the unlock button on the remote) then unlock and lock the car using the drivers door again. After that remove the key from the ignition and your remote should work. If you don't have 2 keys you can remove the drivers inner panel and manually lock or unlock the car by sticking your hand in the door and manually manipulating the locking mechanism. The drivers door does NOT have to be closed when you are programing a new key.
