Results 1 to 13 of 13
    Jul 26 2008
    Jersey
    Wiper fluid icon will not go out after meth install
    I have installed my meth (VAST kit) on my car.
    I drained the wiper tank, and tapped it, then tested it out with some water just to make sure it wasn't leaking.
    A day went by with the tank completely empty, until I could get some meth the next day. After I fill the tank, the icon still displays - constantly.
    It does not beep and briefly display the low fluid icon - the icon is constant.
    I did not remove the tank when tapping the tank, I just removed the wheel skirt and tapped it at the very bottom. Maybe I hit the sensor with the drill bit? but I think I would have saw a piece of plastic come out of the tank?
    Anyway, any help is greatly appreciated.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Wiper fluid icon will not go out after meth install
    I would start with making sure sensor is plugged in. then check wires. make sure you didnt drill through them like you said.
    That light only comes on when the sensor trips it, usually because there is an open circuit because of low fluid. so if its still on and there is plenty of fluid, then that tells me there must be an open circuit somewhere else causing it to trip the light.
    Thats my 2 cents anyway. I expect a check in the mail monday
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jul 26 2008
    Jersey
    I never unplugged the sensor. I guess I'll jack it up again, take the wheel and wheel skirt off and see whats cookin' in there.
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Midwest
    Other than that, how does it feel with the kit working? Mine is partially in....
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Jul 26 2008
    Jersey
    Quote Originally Posted by s vier View Post
    Haven't really had time to test it too much, I don't think you're going to notice much as far as the butt dyno goes. I think you will just notice the car doesn't get heat soaked.
    After 3 or 4 hard runs with my car you can notice it's down on HP once it gets hot, I think the meth will help this.
    I'm going to get a tune for the meth as well and see how that goes.
    Jul 26 2008
    Jersey
    You know what, I was just searching on the forums (on AW) and it seems that the sensor doesn't like mineral water.
    The mineral water mixed with meth does not conduct electricity, which trips the sensor.
    I think next batch of meth I'll run straight up water/meth instead of mineral water/meth.
    Active Member Four Rings
    Dec 11 2006
    Boston
    You know what else doesn't like mineral water? Your motor.
    why are you running mineral water? You should be running distilled water as a mix.
    Jul 26 2008
    Jersey
    grrr it's late and I'm tired.. I meant distilled water! 50/50 mix.
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    my head lamp washer hose came off on my car on the drivers side once and i lost the fliud,
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Four Rings PinoyS4's Avatar
    2018 catalunya RS3
    sf bay area
    my sensor is doing the same thing. i'm running distilled water with meth
    work hard, play hard[;)
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    ive heard mixed reviews on using the washer tank as the sump for the w/m kit. People say the pump is gravity fed? is this true? or is there no reason mounting the motor next to the ABS pump.
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Yes, the pump is gravity fed
    Jul 26 2008
    Jersey
    so basically my meth kit is not working since my pump is by my abs module?
